Timko, I've tested 5G's of BH5 and 1G BH6 and none of it will run for shieeet in MY NF7-S....with Vdimm Vtt Vdd mod's!!! Stock NF7 is even worse. But the UTT does 245Mhz 1T 8,2,2,2.0 on the SAME board.
I have to burn the CPCoff bios back into the board when I want to switch back to CH5/BH5 sticks. Using D26 MantaXT cpcon and cpcoff versions.
For you....
First, it NEEDS the CPCoff bios. For some reason BH5 almost never ever runs 1T on the NForce2 chipset. Second its gonna need voltage. CPCoff it will do 200Mhz+ 11,2,2,2.0 2T @ 2.9Vbios. But to shine on NForce2 its gonna need TheVolt and it will never shine 1T on NForce2.
On an A64 board the results will be much better, 1T, lower Vdimm, etc.
These UTT/VX/SP sticks are a different breed and shine 1T high FSB.... but again NOT on a stock board, you gotta get to 3.2+Vdimm to make them work on a NForce2.
So confirm 200Mhz 5,2,2,2.0 with CPCoff 2.9V first, if it still screws up consider RMA.
