Originally Posted by EMC2
Both types of accomplishments have their place IMO :)
Let's use some other examples where maybe views aren't so polarized...
Is a 100m world record holder's accomplish any less because he can't maintain it for a mile?
Is a marathon runner's world record any greater because it was over a long distance?
or flip it around:
Is the 100m record greater because it was extremely fast?
Is the marathon record less because it was done at a fairly slower speed?
How long is long enough in regards to time vs speed? What's the determining factor? Someones opinion?? Who's opinion???
Take race cars...
Is the sub 4s drag racer's record worthless because the engine would blow if run for a mile at that speed?
If you think so, then is a stock car racer's speed the cat's meow because it was over a 4 hour period?
Or are only 24 hours of Lemans records the ones that mean anything?
Or maybe you have to be able to run it 24/7 for weeks on end?
Why is one time period any better than another in regards to records, why is one any more or less an accomplishment than the other?
Or in the case being discussed... why is the ability to boot into windows and grab a screenie any less of an accomplishment than being able to run pi1M or pi32M more so than pi1M? Are those accomplishments meaningless too if the settings can't be run 24/7 doing anything you can throw at it???
Or how about this thought... is a XXX Mhz OC more significant than an XXX+ZZZ because it was done with air cooling and the other took a prommie to be "stable"? What about a mem OC done with a winnie vs an FX?? Is the FX record less of an accomplishment because it took an FX to do it?
Just because you don't understand one side or the other, don't denegrade what someone else is able to do. If something isn't significant to you, fine, no problem :) But that doesn't mean it isn't to someone else, doesn't mean it isn't an accomplishment, and it sure as heck isn't a just reason to say as an absolute that it is "worthless" or "meaningless"...
If you don't like drag races, don't watch them. If you don't like the 24 hours of Lemans flip the channel. But don't put them down or attempt to lessen their significance.
*gets down off soapbox*
Oh, one other thing... useful information can be gleaned from even suicide BIOS shots. For example, there's useful info in those 400+ Mhz screenies that can be applied to your flavor of OC'ing, whatever it is, if you just open your mind and take the time to look ;)
:toast:
