I run my X850XTpe at 105. I have seen that reccommended for ati's and 102-3 for Nvidia cards on this board. Not sure why, but it seems fine.Quote:
This is very true. There are also many things that can be the weak link on this setup, from a simple bios setting, to not enough voltage, not enough cooling, to the PS on and on.Quote:
Originally Posted by Charloz24
i read that too (didnt angry games say that ?)...the reason might be "to make sure the pci-ex bus is locked"....(by overclocking it a bit).....but well....this might also be an urban myth :)Quote:
Originally Posted by xgman
I can list a bunch of "recommendations" which are all nice and good...but mysterious since there is not ANY explanation why to do this and why to do that...:)
If you are having stability problems, then by all means you should try the beta bios. I would throw 218 on and see if it helps. Jst make sure you follow the instructions for flashing from the officail DFI site.Quote:
Originally Posted by Mastakilla
here is a beta bios list:
http://www.techpowerup.com/articles/other/114
It's not for the lock. But I never did get a straight answer as to why he reccommended this. maybe it is the safe o/c setting for those repective cards for best performance.Quote:
Originally Posted by flexy
This is correct. Its a performance issue. I run my 2 x 6800U at 103mhz for a small added kick in throughput. But, the actual performance difference is quite small:)Quote:
