Humm, I think I saw a pic in plan view and it seemed to fit...Quote:
you make that?Quote:
Yep :)Quote:
Originally Posted by stealth17
see
http://xtremesystems.org/forums/show...3&postcount=42
What do you guys think about this one :)
http://web.telia.com/~u85535737/block.jpg
Specially made just for DFI. Will fit under the card and between two cards in an SLI setup.
I saw MIPS (www.mips-computer.de) sell it. They sell it 45€, about 59$.Quote:
Originally Posted by HARDCORECLOCKER
Mine is running fan less :D, and I don't like watercooling anymore ---> Phase Change :slobber:
ECK
:D HAHA - bought it for 30€ straightly from the guy who made it before he gave it in the hands of a reseller......Quote:
Originally Posted by EclectiK
:toast:
You make it smart :DQuote:
:banana: <-- Love the banana
ECK
Are you still in contact with this guy? :DQuote:
Originally Posted by SAE
:D You have PM.... :toast:
here you go
Made by Håkan aka Hj07
Compared to the others abow, you know its a winner :toast:Quote:
Originally Posted by Marquzz
that has to be one of the sweetest blocks ever!Quote:
i mean look at it..
And i dont even dig watercooling. This is pure :banana::banana::banana::banana: :D
Yeah I say the same. Now Marquzz will get banned cause he shows :banana::banana::banana::banana: and that isn't allowed :DQuote:
Originally Posted by SlackeR
Yummy... :slobber:
:D Yep - looking very sexy - selfmade or can it be bought in a shop...........???
:toast:
does that thing kill the flow though? looks like there are only 2 small channels in the pic :confused:
That's just the rubber sleve. It's actually just one whole channel so it doesn't kill flow that much.Quote:
ic..you getting better clocks with the wc?Quote:
No better clocks, but thats not the point. People are getting 450-500 MHz with stock cooler so it's not that of a chock. The point is to get rid of the noisy stock cooler.
ahh ic. i can hardly hear it over my 4 120mm 130cfm fans (variated of course) so it doesnt really bother me. i reapplyed the thermal paste with AS3 the day i got it and temps stay around 40c so i can even turn the fan speed down alittle with speedfan and it still is fine :p:Quote:
I dont thing that block will work with nvidia cards Marquzz.
:confused: What's the height ???
:toast:
All those blocks are 1/4" ID isn't it? I'm looking for a 1/2" ID nF4 water block. :D
bump! :p:
So buy it and drill/tap a 1/2ID nipple. Its only brass.
