I believe the BIOS temps are diode temps (for my proc, dunno bout others (mine=2600+)) and I get 54-55C in bios. So yeah I'd say those are accurate. You need two sticks of DDR (I geuss put in the blue ram slots (that's what I did at least) and it's automatically twin channel then, no bios option needed.Quote:
Originally posted by fireandsmoke
Sys,
Just curious, does your BIOS show accurate temps? I'm thinking my mobo has whacked out temp sensor and is triggering the new ASUS C.O.P. CPU overheat protection...
And where is the option to use dual channel ddr...I didn't see it in BIOS??? Or was that because I only had one stick in?
f&s
