clock gen is undisirable anyway. How bout straigt up max boot in DC? Maybe only TA's board hosed.Quote:
I noticed in clockgen yesterday that it wasnt locking at 66 so like you I set to 67 and that locked it. But these results were after the fact. I hear on the xp version of this board that if you raise htt in high increments like 200-260 it will cold boot. I am back on the dfi board now. I will just wait for the nf4 boards I guess. This was such a impulse buy. I usuall never buy a board unless I read I review, but this came out after the xp so I figured the problems would be worked out, but I guess that isn't the case. I have the latest bios installed. note if you go to the gbyte site, you will see 3 bios revisions. make sure you flash both(dual bios) to ensure final changes. I hope for the sake of those with this board and those that have them on the wa that Gbyte will fix these issues soon with a bios rev. soon. good luck :)Quote:
Memtested for 6.5 hrs just fine. Bumped it up to 310 now. I'll try 325 before bed.
WOW! Nice going lithan! somethings wrong with my board or maybe I was setting htt at too much of a gap? set your htt at 200 and hit F10. go back into bios and raise to 300htt or whatever and see if it will post without being forced back to the stock settings.Quote:
lithan and with the multi at 9x and the mems at 200 how much htt can you get?
Maneshu Cpu and memory will limit me there so it won't show anything whatsoever about the motherboard.
At mem 100, I cap at 300HTT. I was doing 310HTT @ mem 133 but I didn't try any higher (this board loses all bios settings everytime it can't post and with all the damn raid ports I must turn off it takes five minutes just to get back to my operational settings).
I made a jump from 200-280, didn't try 300 ever.
http://pageperso.aol.fr/misteroadster/28s2841.JPG
I ve tested any K8NS-Ultra it's 100% the same than my K8NSNXP-939.
Works perfectly well with my BH5 with mini 230Mhz and +3,3v in.
Wow! this looks much better!Quote:
Originally Posted by misteroadster
hey trans am you need to test your board again...
I tested it all weekend and I already disasembled it. Everything is going back. I think that board mustve been bad or cpu? My results were nothing like lithans or misteroadster's. Good too see that this board has potential. I take back all the bad things I said about it.Quote:
Originally Posted by maneshu
....another REALLY nice 939 mobo.....
Hello guys i have a problem with mine , if i put my bh5 in the 3 4 slot i´t won´t boot in windows .
Anyone has the same problem ?
Thkx guys
do the vio=vddr mod , set HTT to 4X, FSB 230 in bios and you'll roxx.
I can't tell if you're being serious or sarcastic.Quote:
Originally Posted by charlie
Thkx for the answer but that don´t work , i alredy tried that , with the vio , and my bh5 i can´t pass 210 dual channel configuration.Quote:
In single channel i can bench at 261 2.2.2.5 .
I don´t why this happens strange things , my board is possesed :D
I just wanted to mention that this board is a Perfect match with the xp-120. The heatsink hangs over the dimm slots, but just high enough that you can get ram in and out if you are careful, and this means that a 120mm fan is blowing over your first two dimms (which make Dual channel in this board). Real nice.
Effectively the range 205/227Mhz is absolutely unstable with BH5, you ve to jump it !!.Quote:
Originally Posted by |-jokker-|
I think you've got to retry , hear this :
First solution if you can boot xp@200 :
-use purple dimms
-Vio=vddr
-201FSB in bios.
-Set multi required
-HTT4X
-timings :cas 2/7/12/2/2/5/2/2/2/1X1552
-Set the vcore you want.
under XP Set FSB to 230 with clockgen
Second solution if you can't boot xp@200
-Put your sticks in purple dimms
-do the vio=vddr mod
-set HTT to 4X
-set your timings : cas 2/7/12/2/2/5/2/2/2/1X1552
-set your FSB to 201
F10
-set FSB to 230
Boot windows and use Clockgen to hit the hell :) .
Memtesting 9X245HTT ddr@200% 2x512 bh5 HT@3X VIO=VDDR
2.0-11-13-2-2-9-2-2-2-2x2596 2t enabled
what is vio=vddr?Quote:
mod to run 3.3v line into vdimm.
do you need to do the mod before using a ocz ddr booster? or can you just use the ddr booster and turn it up? I was looking into getting one if I end up going with the ocz el 4200 platinum.Quote:
http://112233445566.free.fr/DCC/wb%20mosfet1.jpg
http://112233445566.free.fr/DCC/wb%20mosfet2.jpg
for those who wants to give more volts to cpu.
WTF is that thing?Quote:
cmon, how does it work?
No you dont need the mod. I did the mod because Im not using a ddr booster.
Mosfets waterblocks for K8NS...939 by a french guy :DQuote:
Originally Posted by trans am
