ok mines cominhg at 4 today, ill let oyu konw how it goes asap.
damn its double sided, i thought that all 256mb modules were SS dimms, but ive got 4 IC's on each side of the ram, is this normal for mushkin?
Isn't that still considered "single bank", and therefore more desirable for OCing. My understanding is as long as it is just 8 ICs than that is considered "single bank". Whether or not the DRAM chips are on both sides or on one side isn't important. At least that is my take on it. I certainly could be wrong. Perhaps someone with definitive knowledge on it will pipe in here.
-Scott
Yeah id like to know...
anyways, for some early results right now im running 250x10 on my NFII
2-2-2-11
3.3v
i started with 240 3.3v, and its already had an error free pass at 250 in memtest...
time to go to 260 ^_^
im so happy right now, on my 512 sticks of bh-5 i could only hit 240in DC with CPC off, CPC is still on and im at 250 :)
edit - i was going to vmod this board, but if im already getting 250 im wondering how much extra vdimm is going to help my FSB, i guess maybe alot as my NB is still at stcok volts, and from my experiance NB voltage helps alot on this board (like 10-15 mhz with my 512sticks)
*edit - what the proper burn in for BH-5 again? its been so long... should i just leave it running 200x13 at 3.3 222 for a few days?
or use memtest #5 till you hit few errrors, leave it running 6 hours....raise few mhz and redo again....
few errors = belowe 100
i guess that means i shouuld have left it running in 260, will do buddy.
Thanks TEDY :)
few errors mean like under 100 after 30 passes or under 100 per pass?
after 45 passes i have 650 errors, is that right???
YES NOT RIGHT
let say 10 passes and check if under 100 errors
