ah, so the valve won't be needed with a commercial oil-sep?Quote:
Originally Posted by kayl
I will let you get back to your work now, hope you can find some nitrogen for pressure test.
hihihih, this is one beautiful phase! Do you want to test your performace?
Tnks
so, does it work ? :)
I haven't tested it been hella busy. I also need more oxy. Damn oxy tourch is so expensive to use at 8 bucks for a bottle that lasts for 20 mins. so frustrating sometimes. I did get a c02 source though. Apparently my boss uses it for the beer freezer in the resturant I work in so I'm gonna get a little from there.
Originally Posted by berkut
I want to view this phase working eheheh.. so, i'm brazilian man, my english is very poorly :cry: :(
tnks
It's okay mod_evil welcome to XS bud.
what load temps are you aiming for? i think your 3.0c will like it if 4.1ghz was on water, im seeing maybe 4.6ghz if cold enough
Yuppo, 4.1 was on water. I can perdict 4.6 maybe, I don't know depends if I can get the time to get this thing up and running. That would technically make my cpu @ 300fsb which would be a nice thing. Currently does 271 unmodded ;)
buy a big oxy bottle 10Liter for example. It will pay off eventually :cool:Quote:
Originally Posted by bh2k
For a cheap source of C02 you can buy a 20g bottle (for paintball, $30) and get it filled for around $4.
that is cheap, i wish it was that much for me.Quote:
Originally Posted by wr0x2
ya just need a fitting and then you can attach you regulator to the bottle and charge
Exactly, but I dont think such a fitting exists :(Quote:
i think you have to get it make up (adaptor fitting, it also needs a needle in it to depress the valve in the paintball cylinder), thats why im gonna use beer gas.
jsu got one made, i know that bowman also uses pinball co2 as well.
nothing is easy hehe
i think the same is with the c02 regulators and using a refrigerant gauges ya need a fitting as well to screw yellow hose on to regulator, haven’t got that far yet.
January though i will find out exactly what i need.
