Do 200MHz 2-2-2-5 with the memory. Try a 200x10 run, 220x10, and 240x10 in each of the benchmarks below.Quote:
Originally posted by JNav89GT
ok sounds good
My asus and FX combo is flakey after I Modded board and took off spreader so I gotta iron out that combo :(
what you want? Stock speeds on everything? And what benches, 3dmark 2k1, 2k3, and aquamark. What about DoomIII demo1? Oh and I assume default LOD on everything.
thanks
Since you have a GT, run both cards at stock GT clocks and use the same driver.
- 3DMark2001 game tests (give compare link)
- Super_Pi 1M
- Pi_Fast
- 3DM2003 game tests and CPU test
- Aquamark game tests and CPU test
Those should be good :)
