Originally posted by Blind_GI
K im gonna try and flash again, hopefully it works this time.
Edit: K the flash was just succesfull, all I typed this time around was a:\nvflash 123.rom (took ur advice on the 123.rom lol).
Idle temps stayed the same... now lets see if I can get anymore out of her :)
Edit 2: Well when i set my clocks to default it goes to the 420/560 I set it to, but I still can't get any more mhz out of it. This is using v1.3 and just changed the 3d voltage to 1.4v and 2d to 1.3v.
Edit 3: Ok I just raised the 2d voltage to 1.4v and it seems I can get all the way up to 456 core using coolbits! Before I could only hit 430 and now im hitting 26mhz higher! My temps only raised 1c idle (not sure on load temps yet), so temps don't seem to be an issue as of now. But my memory is still at its same 1160, but I could have sworn someone said that there mem raised (it shouldn't be able to clock any higher, but I no someone said it did).
Your results give me hope! After I get my temps under control, I hope to break 450 core like you did :slobber:
