SAE from that screen shot
is it from left to right = top to bottom of DFI bios
or from right to left = top to botton DFI bios
i'm quite confused now.... :(
my Alpha settings on the NF7 are the same as in your pic SAE :D... do you run those timings all the time?
Yep, at the moment... but the screenie is taken from my internet rig with the nf7-s and one of tictac's d23 bioses :DQuote:
Hehe. Just completed a Superpi 32M. Have a look...
A lil linky for the last bench before I go to bed :)
http://service.futuremark.com/compare?2k1=7975282
At only 2924MHz :D 265.86MHz FSB!!!
Next one with new CPU :D
Another 2600+ Mobile?Quote:
Might want to buy the old one from you if it did reasonably on air...
Hehe... I dunno nothing, but nearly nothing about its performance on air... a friend already said he'd be interested too. He also is on air cooling. Hmm.Quote:
Yeah, the new one is an RPMW 0352 2600+ :D
SAE.. here... do u know the address for Side Band Addressing?Quote:
Code:****************************
* nVidia nForce2 Data Base *
1) AGP Latency
PCI Bus#2 Dev#0 Func#0 Offset#0D
0D
- 16 clock : 10
- 32 clock : 20
- 64 clock : 40
- 96 clock : 60
- 128 clock : 80
- 160 clock : A0
- 192 clock : C0
- 224 clock : E0
- 255 clock : FF
2) PCI Latency
PCI Bus#0 Dev#8 Func#0 Offset#1B
1B
- 16 clock : 10
- 32 clock : 20
- 64 clock : 40
- 96 clock : 60
- 128 clock : 80
- 160 clock : A0
- 192 clock : C0
- 224 clock : E0
- 255 clock : FF
3) CPU Disconnect Function
PCI Bus#0 Dev#0 Func#0 Offset#6C,6D,6E,6F
6C 6D 6E 6F
- Enable : 01 FF 01 1F/9F
- Disable : 01 FF 01 8F
4) Command Per Clock (T1/T2)
PCI Bus#0 Dev#0 Func#1 Offset#84,85,86,87
84 85 86 87
- Enable : F3 13 0F 03
- Disable : F3 13 0F 23
WARNING! (Not Editable after boot, Can only be set before memory sizing)
5) Alpha Memory Setting
PCI Bus#0 Dev#0 Func#1 Offset#94,95,96,97
94 95 96 97
- T(DOE) : x Selectable Value: 0,1,2,3,4,5,6
- T(RRD) : x Selectable Value: 0,1,2,3,4,5,6
- T(W2P) : x Selectable Value: 0,1,2,3,4,5,6
- T(W2R) : x Selectable Value: 0,1,2,3,4,5,6
- T(REXT) : x Selectable Value: 0,1,2,3
- T(R2P) : x Selectable Value: 0,1,2,3,4,5,6
- T(R2W) : x Selectable Value: 0,1,2,3,4,5,6
- reserved: - Selectable Value: -
- Offset 94 = XY
X= T(R2W) Selectable Value: 0,1,2,3,4,5,6
Y= Reserved -
- Offset 95 = XY
X= T(REXT) Selectable Value: 0,1,2,3,
Y= T(R2P) Selectable Value: 0,1,2,3,4,5,6
- Offset 96 = XY
X= T(W2P) Selectable Value: 0,1,2,3,4,5,6
Y= T(W2R) Selectable Value: 0,1,2,3,4,5,6
- Offset 97 = XY
X= T(DOE) Selectable Value: 0,1,2,3,4,5,6
Y= T(RRD) Selectable Value: 0,1,2,3,4,5,6
6) Normal Memory Setting
PCI Bus# Dev# Func# Offset#
- T(RAS) :
- T(RCD-Read) :
- T(RCD-Write) :
- T(RP) :
- CAS Latency :
- T(RC) :
- T(RFC) :
Wow, Tictac, great info there! :thumbsup:Quote:
1) AGP Latency
0D
- 16 clock : 10
- 32 clock : 20
- 64 clock : 40
- 96 clock : 60
- 128 clock : 80
- 160 clock : A0
- 192 clock : C0
- 224 clock : E0
- 255 clock : FF
2) PCI Latency
1B
- 16 clock : 10
- 32 clock : 20
- 64 clock : 40
- 96 clock : 60
- 128 clock : 80
- 160 clock : A0
- 192 clock : C0
- 224 clock : E0
- 255 clock : FF
6C 6D 6E 6F
84 85 86 87
94 95 96 97
- Offset 94 = XY
Y= Reserved -
- Offset 95 = XY
- Offset 96 = XY
- Offset 97 = XY
- T(RAS) :
- T(RCD-Read) :
- T(RCD-Write) :
- T(RP) :
- CAS Latency :
- T(RC) :
- T(RFC) :
It's PCI Bus#0 Dev#0 Func#0 Offset#49
...set it to 01 to disable, 03 to enable :)
:D
Ahh, and the last one ;)
grrrrr... 3.2GHz :slobber:
is that Pentium 4? :lol:
congrats.... keep pushin bro... :):banana: :toast:
No Pee4 ;)Quote:
Hehe, but as fast as one :p:
Did you see the setting for SBA?
ok got it... thanx :toast: :banana: :banana:Quote:
No Pee4 ;)
little off topic but...
SAE, how did you get CPUZ to detect your chip as a mobile AMD athlon? The frist screen shot in this thread has it as the usual unknown cpu type, but your recent ones have it detecting.
The bios has to recognize it ;)Quote:
(1st screen: 2-17 alpha, later 5-5 21T6 AdvModDev Edition ;) )
Thx again AdvModDev :toast:
http://service.futuremark.com/compare?2k1=7976575
No new record, but nice :)
duuuuude..
u have to stop right now, its not fair, lol
U cant be posting stuff like this right now, u gonna cause a riot, heehee.
Man u really pushing the boundries, total respect to what youve done, you putting us all to shame.
One of the true overclockerz
:toast:
On a side note, I found out how system limited 3d01 is! Even with the card in sig, only nature showed any meaningful improvement!
:eek:
No way for challenging for top spot with this platform on warm water, lol.
mong
Thanks mong, buddy :DQuote:
Originally posted by mongoled
duuuuude..
:toast:
:eek:
mong
I think there's more to come ;)
I did some 3dmarking, but have not been able to break my record yet... two time the same score ;) 25349 :p: At 12x266 and 12x267 :) R9800pro is limiting me :(
ALRIGHT!!Quote:
I just got me a 2600+M IQYHA 0352 RPMW from the egg :slobber:
DFI has my infinity thanks to a crooked socket, right now.. cant wait to get her back....
Been seeing nothing but excellent results with this chip! :toast:
Oh, and that 3.1ghz on 1.96Vcore...
That is VERY NICE! :slobber:
Does the extreme temps help the OC at such a low voltage? Cuz my SLK is jsut aching now that I saw that one. I figured it was over 2.15Vcore!
Hehe, the chip can do 3.13G stable with 2V set in bios :D (261Fsb)
I gotta get me a mach II :slobber:Quote:
:D
Nice FSB there, 268 is nasty.
Not an original idea at all: get a GF6800 or Radeon X800...Quote:
