2T is only supported by CG stepping and aboveQuote:
Originally posted by HKPolice
BTW, the 2T command rate doesn't seem to work with my C0 stepping A64... I try to enable it, and it just goes back to disable after pressing set. I don't think this is a bug with your program though since I tried modifying it with wcpredit before, and it did the same thing. Any reason for this? :confused:
