Originally posted by STEvil
ok, time for the bad news.
The reading we are getting off the mosfet is bad, I believe. *:stick:
As you will see in the attached picture below there is a point where you can measure your VDIMM next to the 3rd DIMM slot.. it appears to me that what I have been reading off the mosfet is somehow incorrect... somehow. :stick:
I also found another point just below the VDIMM mosfet that apparently is either VTT, VBT, or VREF.. dunno which of the 3 it is, but its the correct voltage for match the first measure point in the pic (both measure points not on the mosfets are spots for capacitors.. could putting capacitors there help with high fsb?).
Still, this leaves a question: How the hell are the mosfets showing an incorrect voltage?!?! :stick: :confused: :stick:
My voltage reading at the mosfet raises about 0.03V everytime I do the trick although it should be 0.3V.
