well here is my old rig, in the middle of upgrading to a64.
http://www.sjohnson.info/bigfoot/WeS...ture%20011.jpg
http://www.sjohnson.info/bigfoot/WeS...ture%20002.jpg
I have purchased a professional chiller and will be installing it this Winter. Remember if you put rad outside or in chilled water you will have to deal with condensation. I plan to use the chiller to get coolant just above ambient. I'm not interested in dealing with condensate at this time![/QUOTE]http://www.aqualogicinc.com/chillers/deltastarmain.jpg
It's a Aqua Logic Delta Star 1/3 HP Chiller DS-4 with an optional remote thermal control.
http://www.marinedepot.com/IMD/cn_medusa.jpg
I plan on mounting it in the attic to keep heat out of the computer room. Just so happens ther's one right next to the room! :p
This is my main rig:
http://www.bbpix.com/pix/LianLi9CJS16.JPG
Another installed in the "out of control room"
http://img.photobucket.com/albums/v2...t/dscn0021.jpg
Another one:
http://img.photobucket.com/albums/v2...t/dscn0030.jpg
This is my other "water project". It houses 50 3 - 5 lb trout:
http://img.photobucket.com/albums/v2...d/DSCN0005.jpg
http://img.photobucket.com/albums/v2...d/DSCN0010.jpg
That other "water project" is just beautiful. Great work! :toast:Quote:
Originally Posted by Uncle Bob
latest update on my setup - full pics at http://www.fileshosts.com/watercooli...650_600/large/
CPU Cooling: MCW6002 Waterblock > RES > (MCP650 + MCP600 in series) @12.3v + Bravo Heatercore 2x 120mm Delta 190cfm @ 145cfm/each > MCW6002 Waterblock
http://www.fileshosts.com/watercooli...MCW6002_06.JPG
http://www.fileshosts.com/watercooli...MCW6002_09.JPG
http://www.fileshosts.com/watercooli...MCW6002_20.JPG
http://www.fileshosts.com/watercooli...MCW6002_22.JPG
http://www.fileshosts.com/watercooli...0_600/temps/1/
http://www.fileshosts.com/watercooli.../1/temp_00.JPG
http://www.fileshosts.com/watercooli.../1/temp_02.JPG
Thanks! We really have fun with the (Piranhas) trout! They can jump over 2' in the air after various bugs or when fed.Quote:
Originally Posted by Nomjr
http://img77.exs.cx/img77/3310/WaterCooling001.jpg
http://img77.exs.cx/img77/8392/WaterCooling002.jpg
http://img77.exs.cx/img77/3007/WaterCooling006.jpg
http://img77.exs.cx/img77/5929/WaterCooling007.jpg
http://img77.exs.cx/img77/1695/WaterCooling008.jpg
http://img77.exs.cx/img77/8183/WaterCooling010.jpg
Oh nice triple rad setup Uncle Bob!!!
On my battlefield I'm now working on something I've never tried before which is a MICRO-ATX watercooling setup. Going to use a Lian Li PC-35 w/ a single 120mm lytron radiator I have. Going to require a bit of refitting and such, but I think it's going to come out really nice.
Now wih S939 :)
http://people.freenet.de/funkflix/pca64.jpg
I love that German refinement, I am thinking about getting an innovatek WC-set
here is mine:
Looks nice, except for the tiewraps :P
What temps do you get with that setup?
Thanks :).. Ambient= 25C, Idles= 31-32C, Loads =36-38C.Quote:
Originally Posted by Ricarus
sorry using wab cam :([IMG]C:\Documents and Settings\Admin\Desktop\picture 005[/IMG]
you cant link to files inside of your computer...
use a free picturehosting service. http://www.theimagehosting.com/login.php
specs:AMD64 3800+ @ 2.6Ghz, Abit AV8 socket939, Geil Ultraseries value dual channel PC-3200@2.5 7-4-4 cas, Ati 9800 pro.@378c/338m, SB Audigy2 zs plat. pro., 200G htich, 250G maxtor, 74G raptorcase:lian li pc-v1200
cooling: DD tdx + maze4 + black ice xtreme 120 + bay rez + 2x "c-systems" mark 2 pumps
moved one of the harddrive cages to make room for the rad and am working on stelthing the drives and rez. also like to get a window in and better wireing
waterblock-homemade
60x50x10mm
http://www.pietach.republika.pl/Overclockers/blok1.jpg
http://www.pietach.republika.pl/Overclockers/blok2.jpg
http://www.pietach.republika.pl/Overclockers/blok3.jpg
80x50x10mm (copy Uriel)
top z plexy 10mm
http://www.pietach.republika.pl/Overclockers/blok4.jpg
http://www.pietach.republika.pl/Overclockers/blok5.jpg
next prototype
http://www.pietach.republika.pl/Over...s/podstawa.jpg
<img src="http://www.pietach.republika.pl/Overclockers/uszczelka.jpg " />
<img src="http://www.pietach.republika.pl/Overclockers/podkladka.jpg " />
<img src="http://www.pietach.republika.pl/Overclockers/elementy.jpg " />
<img src="http://www.pietach.republika.pl/Overclockers/calosc.jpg " />
<img src="http://www.pietach.republika.pl/Overclockers/calosc1.jpg " />
<img src="http://www.pietach.republika.pl/Overclockers/bloczek.jpg " />
<img src="http://www.pietach.republika.pl/Overclockers/bloczek1.jpg " />
<img src="http://www.pietach.republika.pl/Overclockers/bloczek2.jpg " />
<img src="http://www.pietach.republika.pl/Overclockers/bloczek3.jpg " />
<img src="http://www.pietach.republika.pl/Overclockers/bloczek4.jpg " />
<img src="http://www.pietach.republika.pl/Overclockers/bloczek5.jpg " />
Zbiornik na wode(water):
Waterpump AguaelPFN350 - 350l/h (made in Poland)
http://www.pietach.republika.pl/Over.../zbiornik1.jpg
http://www.pietach.republika.pl/Over.../zbiornik2.jpg
http://www.pietach.republika.pl/Over.../zbiornik3.jpg
http://www.pietach.republika.pl/Over.../zbiornik4.jpg
http://pietachwpc.w.interia.pl/krucce.jpg
Radiator(made by Pietach):
http://www.pietach.republika.pl/Over...chlodnica1.jpg
http://www.pietach.republika.pl/Over...chlodnica2.jpg
http://www.pietach.republika.pl/Over...chlodnica3.jpg
http://www.pietach.republika.pl/Over...s/zapinka1.jpg
http://www.pietach.republika.pl/Over...s/zapinka2.jpg
http://www.pietach.republika.pl/Over...s/obudowa1.jpg
http://www.pietach.republika.pl/Over...s/obudowa2.jpg
that is pretty trippy. How is the flow with the last block that you showed. From the looks of it, its has to give horrible flow...
And how does each of them cool?
my dual xeon @ chenbero cube.....
http://hardwareluxx.de/mzierer/cube/wakue_04.jpg
http://hardwareluxx.de/mzierer/cube/wakue_05.jpg
http://hardwareluxx.de/mzierer/cube/wakue_06.jpg
>> Pietach
Niece CPU WB (last project) :D
Radiator - hmm - I think not great PERFORMANCE but nice work
A lot of good work here :toast:
Pozdrowka dla rodaka
woa that rad is a beast!
overkill (which is good! :D )
WC made by Pietach rev1.2
http://pietachwpc.w.interia.pl/bloczki/010.JPG
http://pietachwpc.w.interia.pl/obudowa/001.jpg
http://pietachwpc.w.interia.pl/obudowa/002.jpg
http://pietachwpc.w.interia.pl/obudowa/003.jpg
http://pietachwpc.w.interia.pl/obudowa/001a.jpg
Click me water block - more foto
mosfet & NB (VIA KT333)
http://pietachwpc.w.interia.pl/obudowa/004.jpg
Shroud & 2x Fan 92mm 5V
http://pietachwpc.w.interia.pl/obudowa/005.jpg
http://pietachwpc.w.interia.pl/obudowa/006.jpg
pump Aquael PFN350 350l/h
http://pietachwpc.w.interia.pl/obudowa/007.jpg
http://pietachwpc.w.interia.pl/obudowa/008.jpg
http://pietachwpc.w.interia.pl/obudowa/009.jpg
http://pietachwpc.w.interia.pl/obudowa/010.jpg
http://pietachwpc.w.interia.pl/obudowa/011.jpg
http://pietachwpc.w.interia.pl/obudowa/012.jpg
http://pietachwpc.w.interia.pl/obudowa/013.jpg
prime95
1700+ @ 1500+ 1,4V : 32*C
1700+ 1,6V :34*C
1700+ @ 2400+ 1,75V : 38*C
http://www.neffing.com/pics/albums/userpics/1%7E2.jpg
http://www.neffing.com/pics/albums/userpics/2%7E2.jpg
http://www.neffing.com/pics/albums/userpics/3%7E4.jpg
That LGA775 WW adaptor was made by me :D
http://www.neffing.com/pics/albums/userpics/4%7E2.jpg
It's alive!!!
http://www.neffing.com/pics/albums/userpics/6%7E0.jpg
I know my loop order is pretty bad, but thats the only way it will fit my case without cutting my case into pieces. It seems to be working fine too.
wow stardust how is your radiator holding up like that?
