I figured out my no boot problem last night.Quote:
Originally posted by Hobocrow
I know you will, Bud ... Sorry, bout my bad manners earlier, I didn't memtion that your system looks great ... and it does! :)
I had sprayed the socket area of my mobo with conformal coat(that was something I had never done before) "NOT"
Evidently the C.C. had kept the processor from making good contact in the socket plug. I cleaned it out good with Acetone and it booted right up:D
Thank You Lord :D
HoboCrow - as for your question about the pressure switch, I don't see why you couldn't use a switch with a lower cutoff point if it make you feel better. My low stage does creap up to 350psi sometimes, during startup. I'm glad mine is set for 400psi.
