I'm running @ 2640 Mhz with my 2600+m on a ASUS a7n8x deluxe rev:2.0 with 1.825 Vcore.
Using an SP97.
Using an SP97.
I couldn't resist and ordered a new mobile. Week 0401. I hope it's a good one.
I have a week 0401....
2.70ghz at 1.90vcore
Enjoy. I could possibly get into windows at 13x220 with it, but it wouldn't be stable by a long shot.
[IMG]http://upl.silentwhisper.net/uplfold...hz0352rpmw.jpg[/IMG]
Fast test
Aircooled!!!
Nice, pal :thumbsup:
P.S. My stepping is like yours, but with batchno 475 (does not mean anything at all...)
More testing this is with very bad temps... it´s very hot here in sweden know. Did this test becuse i geted cpu 2 to day it´s looks like a killer.
-------------Cpu nr1------------------------------------
AXMG2600FQQ4C Y911422A40267
IQYHA 0352 RPMW
2585.27Mhz
45/32 temp cpu socket/cpu diode
1,725
Stability:Super pi
--------------Cpu nr2------------------------------------
AXMG2600FQQ4C Y911422A41577
IQYHA 0352 RPMW
2616Mhz
1.725v
Stability:Super pi
2600+ 401 IPMW @ 2.73 with only 1.88vcore 5min after i got cpu! may do it with less juice after some folding for a few days.
12.5x219 benches rock stable 13x219 needs 1.95 over 219 kicks something in that drops benchies a good bit so im stuck with that as max FSB on this board.
Did burning in help anyone attain lower voltage running with these?
http://upl.silentwhisper.net/uplfold...881superpi.jpg
Still 30c temp out on the day, did this on the night when the temp droped under 20c
i though that the chips were limited to a multi of max 12.5
how are ppl using 13 and 13.5x?
No, you can use every multiplier... it depends on the board. ASUS for example cannot use higher mults than 12.5x iirc.Quote:
Do the 5bit multi mod and you can use 13+.Quote:
My new second mobile Barton:
http://www.hot.ee/temp5/2400+.PNG
Stepping is very close to world nr 1 New Beetle's 2500+
With air cooling I have this:
1848Mhz - 1,15V
2000MHz - 1,25V
2145Mhz - 1,35V
2256Mhz - 1,45V
2352Mhz - 1,55v
2436MHz - 1,65V
so, it's not bad :D and very close to New Beetle's results
conf:
M-Barton 2400+@250x12=3000MHz/2V
DFI NFII Ultra Infinity
2X256MB BH-5@CL2-2-2-5-9-15/3,5V
Antec TP550W
and first test with LN2 (I choose nice 3GHz for first testing :D)
(CPUZ is showing some strange numbers, but thgclock is accurate, as always)
SuperPi 1M:
http://www.hot.ee/temp5/spi-3f-33s.PNG
and pifast:
http://www.hot.ee/temp5/3g-pifast47s.PNG
btw, my first m-barton 2500+ with RDA+ give me this: 3343Mhz screen
Max Screen XP-M 2500 AQYHA 0410 TPMW
DFI Ultra Infinity Rev A
Vcore : 1.975v
2*256 Adata BH5 2/2/2/2/11/9/12
Full Aircooling
Thermaltake Volcano 7+ :D
T° : 45-50°
http://membres.lycos.fr/boblemagnifi...pm@2812mhz.png
My new XP-M 2400+ IQYHA 0351 runing Prime95 @ 2752MHz with HOT 29ºC water, Vcore 2.15V, NF7 v2
Should try to get 2.8GHz stable with HOT water :D
Best screenshot: 2714.6 MHz
Stable @ 2629 MHz
Equipment:
Motherboard: Abit AN7
CPU-Cooler: Simple air cooling (modified Q-Link Vantec V4A-C7040 T.M.D 5600 rpm seen as about 6000 rpm)
CPU: Athlon XP-M 2600+ Stepping IQYHA
Hmm guys I might give you a run ofr your money P95 testing right now at 2600@1.75v. I"m getting a new power supply so that should help me a lot as I push it further.
::EDIT::
It passed P95 for one hour at 2600mhz@ 1.75v. It has passed at least 45min of P95 2700mhz @ 1.85v.
nice score!
unfortunatly i don't have a mobile...uff
i have a 2800+...
Screenshot: 2871MHz
http://www.kanetti.fi/~electroid/scr...cpuid/2871.JPG
AXP-M 2500+ 0410 TPMW
DFI Ultra Infinity + some mods ;)
Vcore ~ 2.15-2.2V (bios)
Water cooled, water temp 18 - 20C
:D Dry Ice coming...
edited
AthlonXP-M 2600+ IQYHA 0401 MPMW
13*200 = 2600MHz @ 1.875V (as set in BIOS) with an Abit NF7-S 2.0 and Antec TruePower 480W. Votlage reported by MBM5 is around 1.80V during full load. Pretty good chip, although others with the same stepping have gotten even better results. Migh add that cooling is done with an SLK-900A and 3400RPM Enermax 80mm fan.
AthlonXP-M 2500+ IQYHA 0405 SPMW
12,5*200 = 2500 @ 1.925V (as set in BIOS). Same system as the above one (this is the CPU I used before buying the 2600+). Crap chip.
My new IQYHA 0401 XPMW 2600+ XP-M
http://people.freenet.de/funkflix/xpm.jpg
http://people.freenet.de/funkflix/xpm2.jpg
Now i try the 2800 MHz :banana:
Do try the small ffts with prime to stress the cpu... the large ones only stress the mem as they don't fit into the cache.
8k to 512k I would suggest. :D
good jobQuote:
Originally posted by Electroid
Screenshot: 2871MHz
AQYHA or IQYHA ?
My 2500M AQYHA 0410 TPMW
NF7 no mod
Full Aircooling : Volcano 7+ (6800tr)
2.06/2.1v bios
temp cpu 50°
temp room 17°
http://membres.lycos.fr/boblemagnifi...pm@2885mhz.png
Boot a 2908mhz but no screen :mad:
this week end, I test with a Mach II and the NF7 full modded :banana:
Hi !
What's up to the ASUS K8N-E Deluxe ??? :confused:
