Hehe its 2:37AM here :D
you have an overclocked body:bows: :bows:
mine is "stock"... lol
http://fugger.netfirms.com/9935.jpg
A huge jump in nature without that fade to black. Not sure why its happening but its happened a few times.
61fps nature
Too much mem clocks perhaps? :)
Good luck for your bench session. Im off to bed now :D
It happened at lower mem clocks and I am at minimal tearing on
screen.
It just ends without the fade to black and gives score. I feel its a bug and wont post the score.
Have you seen this problem before?
Havent seen nature buggin on mine yet. It does it in mark2001 when too much mem clocks but not in mark03 so far.
Unless your running at 670/480 you wont see 60+ fps in nature without a bug of somekind.
Yep, fade to black must be a seperate routine in the benchmark it to quit and still give score. My memory was at 459 iirc
Thats plainly insane, same score and with only 4GHz cpu speed.Quote:
I just camt my head around how you peeps can improve your score like that. Have a top score then someone beats it. Then your another run and there you go, a top score again.
This is intresting to watch!
BTW, macci why dont you get a FX? And go for top in 01?
Macci,
Nice score my friend. Gotta love those numbers:D
OPP
Wow this is pretty exciting to watch... It's nice to see you guys encourage each other, shows a great deal of sportsmanship! Keep up the great work guys!
"OOO macci just posted a score 98783dmarks, SAME AS OPPAINTER!!, but maccis only at 4065MHz, crank the CPU speed up n lets see some 10K goodness."
3dmark 2003 doesnt really care about cpu speed but yea if Macci can get his cpu stable any higher clocks he just might do 9900 marks :D not much but enough to be #1
Great Job fellas! Man , I would love to see 60fps nature in 3dmark03 on my system. Wow, it seems Fugger has gotten a pretty high score , but a bugged run which is too bad.
my 3dmark03 score increased from 3649 to 3798 pts. stock, when i upgraded just the cpu from 2.4 to 2.8ghz. So cpu speed can be a factor too.
CPU speed only plays a large role when it is your bottleneck.
For example, when I overclock my CPU from 2400 to 3200 my score increases fro 6,600 to 7,100 - a 500 point increase. Obviously I was overpowered in the video area and underpowered in the system area.
Otherwise it doesn't make as much of a difference.
Then I hope macci is able to get his p4 past 4050MHz, like 4.3GHz would be sweet :D
my god!
Why does 3dmark read clock speeds incorrectly? It reads the FSB right and no matter what 1:1 5:4 3:2 it is always posts lower than the actual clock speed.Quote:
Mad scores guys!!!! I think a great bon voyage to the R360's will be the 10k mark by all 3 overclocking madmen!!!
It reads mine correctly...
Hopefully FUGGER can sort his bug out.
When are you benching 3dmark01 macci ? Nice video card clocks.
With r420/nv40 maybe they'll be powerful enough with their new shaders to start showing cpu effects in GT2-4 ?
Regards
Andy
It looks like Macci has got back on top!
http://imagehost.vendio.com/preview/...vitc/macci.JPG
http://service.futuremark.com/compare?2k3=2083510
yeh i know dude, but if he can run his EE at like 4.3G-4.4Hz then that will be enough to get him 10K for sure, 3dmark 03 is pretty damn ignorant of CPU speed, but not THAT ignorantQuote:
:up:
good morning...
hi mg84 :D
waiting for the next update...
:DQuote:
Originally posted by Melkizedek
:up:
good morning...
hi mg84 :D
Go macci go, go macci go.
All i will say, good competition.
wow Macci could make history! 4.1GHz and 77 more marks to go! another couple hundred MHz on the cpu and 10k is his!!!!!!!! I think he can do it, lets find out!
