Dave's eastbound and down ;)
http://www.youtube.com/watch?v=xnRwQjTYfGI
http://www.youtube.com/watch?v=bTUrWYv2vtU
Can you count suckers? I say the future is ours, if you can count...
Can you dig it
To recap:
After the gallant efforts of the XS-WCG Linux Team
http://img.techpowerup.org/131103/Pe...gascar1519.jpg
MM has been empowered. The Beast has been released!
http://img.techpowerup.org/131103/rodChair.jpg
The Only thing that could have made this thread more fun :toast:
http://img.techpowerup.org/131103/fu...moments_08.jpg
:D
lunchtime and Free-DC says...... (drum roll)......20,848
Shall we have a go at guessing today's total?
I say 45K
I think you are close, but I guess it will do 47K.
Well considering I did a update manually at say 4:30am and not another till 12:20PM the numbers just might be better than you think..:D
I need something like the config file that sends the completed WU back as soon as they are done..
<cc_config>
<options>
<report_results_immediately>0</report_results_immediately>
<max_file_xfers>20</max_file_xfers>
<max_file_xfers_per_project>20</max_file_xfers_per_project>
</options>
</cc_config>
will probably help your rig..... report immediately should only be set to 1 if you insist on getting this ppd stuff sorted fast. set this level of max_file_xfers in normal use to get things done quicker when it does upload which it should do all by itself
I think it goes in /etc/boinc-client The file is named cc_config.xml
You can try using gedit from the terminal.... I forget if that folder will force you to use the terminal or not so maybe wait for one of the others to chip in on this.
Assuming it does, in terminal type:
sudo gedit /etc/boinc-client/cc_config.xml
enter your password and hit return
when gedit opens, copy and paste the file above and hit save.
close gedit
from manager make it read the config file
this machine :eek:
Day two stats
Statistics
Date ................Total Run Time...... Points Generated...... Results Returned
11/03/2013....... 0:047:17:49:17............ 304,069......................... 1,069
Oh yea, I forgot....:woot:
Now this made my day! :D
http://stats.free-dc.org/stats.php?p...wcg&sort=today
Suddenly I felt a disturbance in the force...something I have not felt since...
....wait a minute, why is my wallet hiding under the bed?!!!
MOVIEMAN!!!!!
(Hello sir, been a while. Now - what is all this photoshop craziness showing all of those cores? You almost had me believing but then I read this you & Linux thread!)
if you want to periodically monitor your temps with sensors command use
watch sensors
it will run sensors command every two seconds...
(and you can learn more about watch command with man watch :D)
(and you can learn more about man command with man man :D )
(and you can learn more about everything by going to /usr/share/doc/ and start reading :D)
Ok, here's some info for you guys to chew on:
I first started up this machine on Linux at app 6PM Friday night.
Say I got WCG running app 10 mins later after looking around a little to get at least a tiny feel for linux.
At 6AM today I broke 100,000BOINC or 700,000 WCG points.
Yea, 60 hours to 100,000 BOINC
That took me almost a week on the SR2 system with 2-X5680's at 4200MHz
Attachment 131729
Attachment 131730
She is a monster.
:up:
Day3
Statistics
Date.......Total Run Time...........Points Generated......Results Returned
11/04/2013..0:045:04:34:28..............290,184................981
Must've been those BETA WU that slowed me down today! :D
Just broke one million WCG points since last Friday at 6PM! :D
Attachment 131739
i took the liberty to add your host id to top hosts overrides list, should pop there during the next update
annnndddd 7th :P
What a surprise..
We might have to get a custom compiled kernel into that beastie to wring the last few HP out of her. ;)
What desktop environment did they give you, Dave?
Cinnamon, which is based on GNOME 3.0. I believe that stock Linux Mint 14 Cinnamon uses Cinnamon v. 1.6.7. I am pretty sure I did update Dave's Linux install so it may be Cinnamon 1.8 now. It's hard to remember after doing 5 installs, 4 of which were dual boots in the past month.
Have to bear that in mind. I use XFCE personally, both in Slackware and Mint. Might have to throw a Cinnamon install in a VM in case I'm Johnny on the spot for some help requests.
I've heard good things about Linux Mint XFCE. When I looked into Mint, it seemed like a toss up between the two based on peoples recommendations and anectdotes. Cinnamon appeared to be a little bit easier to use from the majority of the Cinnamon proponents as compared to XFCE, but that was just my impression after reading umpteen posts about Cinnamon vs MATE vs XFCE vs blah blah blah. I will say that Cinnamon was much easier for me to grok than the wretched Unity interface in Ubuntu.
