good i'll drink to that :toast:Quote:
Originally posted by bachus_anonym
as a person that pretty much started all this and also on behalf of Sai, if i can, i say we're done on the subject...period!
On with the quest for more FSB :D :banana:
Awwhh come on guys, stop arguing!
http://www.storainternet.com/rage/pics/arguing.jpg
Man. Thats a bit harsh, but i see your point.
Thanks gentlemen! :toast: Now, let's get back to benching :)
forget benching.. i wanan see a max fsb screenshot!!!
i was trying to do a similar feet.. but i fell short.... twice.. sooooo im just gunna stabalize my system and move on.. maybe get phase change.
:D lol :D me too!
Read the post above yours and the one above that and you'll see it stopped before you posted.Quote:
Just a lame attempt to post a daft pic methinks :D
So...
http://ricjax99.50megs.com/forumpics/PRYORSTFU.jpg
SLK-900U and dual 35cfm 60mm fans should keep your temps down.
Hey Lastviking, you liar ;) :D
Do confess, your room was a block of ice and you - frozen like an ice age man - waited for your system to finally defrost you... :D
The nice effect was to clock it like mad but you were more happy about being able to move again ;) And to get the windows closed, hehe...
:toast: Amazing results, must be an extraordinary cpu/and also ram+board there :)
But for stability I doubt it can be 100% stable... this board is the bottleneck since it blocked my oc because of high fsb/VCore :(
But the effort counts and the results are overwhelming.
Well done :thumbsup:
P.S. I cannot see the first pic with your results. Bad link?
SAE i think my board geting stronger with more modds :). Now i cane run 3Dmark2001 @ 268Fsb+(Win2k) with passive cooling @Nb and Sb and no fan over memmorys"Room temp"20-25c. Before the new modd it only did 259fsb(Win2k) in room temp with active cooling @ Nb Sb and memmorys. But one thing sucks the out temp is only +5 now....:/ before -11-> so i cant test high fsb tests..
:stick:
Hey. That's great results. But do you think it's all due to the low temps or the stronger modding? :)
I hope you can tell me what you modded in what way on your board... can PM me as well ;) What's the new exciting mod??? :D
As I mentioned before I unfortunately have to wait for my replacement LP B for the dead infinity :( I would be very very glad to see it here on my desk within 1 week... but it depends on dfi's rma - speed... :rolleyes: I think there's only sth wrong with bios hardware but I am fed up now with those failing infinities :mad: I want a LP B too ;)
Re: -=2800Mhz"10x280Fsb"=-=NF2=-=Aircoled=-
:slobber: :up: :sofa: :worship:
i think with an higher vdd you can get 290
on my infinity :
vdd 1.8=255 screen
vdd 1.9 268 screen
if we can take the vdd regul to set 2v :) :p
Higher VDD will do it for my lanparty too. Not saying that the memory is fully stable but the board/chipset is definetly holding back at high FSB.
Anyway if anyone's interested my lanparty board can do about 265MHz prime stable. Had it up and running at 278 doing light benches yesterday. That was with watercooling and pretty low cpu clock (<2,5GHz) dunno if it can do the same with the prommy and 2,7Ghz<.
Still got the original coolers on both south and north bridge. Added some sinks to the mosfets though. One low rpm 120mm fan cooling the whole thing. Some better cooling on the nb and I'm sure it would do better. Not that it mathers much tho since my mem cant do any real benches at such crazy speed. Sandra and such will probably run.
When it comes to Vcore my board can do about 2,08V with 100% stability. Will boot all the way up to 2,2 (never tried any higher) and do light benches. Anything real and it craps out sooner rather than later... either locks up or reboots. Holds back my barton some 50MHz or so Im afraid. That kinda sucks.
Also I tried the Vdd mod. That however did'nt work. The mod itself seems to work but the board somehow regulates down the voltage. Got it to overvolt with some 0.1V but then the board wouldnt post, and as soon as I raised the omage even so little the Vdd dropped to the point where it was before the mod and the board functioned again. Have to look into that later I guess.
Still this is without any doubt the best nf2 based board I have ever seen. Im sure the vdd issue can be resolved.. the vcore thing is a bigger problem.
Nice fsb Hognert :thumbsup: What dimm voltage???Quote:
[...]Still this is without any doubt the best nf2 based board I have ever seen. Im sure the vdd issue can be resolved.. the vcore thing is a bigger problem.
The vdd thing is what I was telling you all from the start ;)... there could be more stability with added vdd since the chipset causes the errors with high fsb and high vcore.
The vcore probs are due to the unsufficient voltage regulation :(
I'm using some 3.65V or so. Tried some 3dm just now and it ran fine up to 272MHz FSB with tightest settings. On a low end card tho (gf2mx) so Im not sure it can do it with a fast card. Frankly I doubt it can ;).
http://home.no/deadeye/272-3dm.jpg
Hognert you got a killer board there :)
What are your
+12@?
+5@?
+3.3@?
And Taiwan or china board.
http://upl.mine.nu/uplfolders/upload9/2703dmark.jpg
Only a fast test. Need more time to tweak and connect the modds again.
Ps...I have tested the vdd modd and it works fine..but i´m have only using it with high fsb tests. No 3Dmark
Nice stuff Lastviking :). My 12 and 5v are pretty much dead on.. the board shows the 12 as 11.8V or something during full load. My 3.3 is at 3.7V or so I believe. You think higher rails would make a difference?
Gonna check out that VDD again right now :), need to get that one working.
Also I see from your screen that there's clockgen for nforce2 now ;). I had no idea. Need to get that one. Handy thing.
I couldnt see your 3dmark score in that pic hognert :(
[edit] found it, nice score for that card
as long as your psu is within the 5% tolerance you should be fine, but if you want to run vdimm that high just run it from the 5v line (im not sure but do the infinity nf2 boards come with that stock?)
nice FSB there lastviking, how does it feel to be up with the p4's? Also, what card are you using (9800p?), I havent read the whole thread yet, but im going to
:toast:
I don´t know if high rails make difference but i could´t belive you got so high without many modds..I think my boards sucks..it´s have i big problem in WinXp over 218fsb.... and i don´t get any higher with higher vdd(tryed 2.033) but i didn´t gain any in 3Dmark2001...My board have some heat problem i think..but i don´t know where....If you need help with VDD PM me or use icq i have added you.
LastViking,
what country is your board made in?
btw, nice FSB you got going there.
You seem to do outstanding job in FSB oc'ing the board but what about the video card. You got R9800pro, right? Why don't ya supercool your card too. I think you have a lot of potential.
