One important question:
Does Quadro have full DP rate or not? Afaik, DP is more power intensive, hence the lower clocks on the Teslas and on Titan once you enable DP. It was always my understanding that Quadro is a workstation card. Geometry, graphics etc. And Tesla is for DP. That's the whole sense of Maximus: Put one Quadro and one Tesla together, each with their specialized tasks.
Second question:
Will a potential 15 SMX-GeForce get GK180 or GK110 and if there really is an improved energy efficiency, is it due to design or due to better binning/process improvements over time?
Third question:
TDP != power consumption. Or better: Is TDP (Quadro/Tesla) comparable to TDP (GeForce)?
Under sustained gaming load, Titan and the GTX 780 often clock near the base clock due to the low temperature target:
http://ht4u.net/reviews/2013/nvidia_...st/index10.php
http://ht4u.net/reviews/2013/nvidia_...iew/index9.php
http://www.hardware.fr/articles/887-...ost-tests.html
http://www.hardware.fr/articles/894-...ost-tests.html
https://www.computerbase.de/artikel/...-gtx-titan/19/
https://www.computerbase.de/artikel/...80-im-test/11/
Now with those lower clocks, power efficiency is much better already. The Titan uses about 206W on average, the 780 uses 189W (cards only, no efficiency losses at the power supply, direct measurement):
http://www.3dcenter.org/artikel/eine...rafikkarten-st
I simply don't see that much potential for improving energy efficiency between comparable operating points (either no boost vs no boost or full boost vs full boost). Voltage is key here. The difference between no boost and boost is a whopping 0.16V! With my Titan, I measure 50-70W difference between base clock@1.0V and 1006 MHz@1.162V (whole system), and this is in line with the measurements of other reviews that made this kind of investigation.
