Those are power saving and oc profiles. If you are oc already probably won't work. Not sure on why it's not holding your settings. Will ask hq
Mem clocking of PSC and BBSE kits seems to be hard on MVIE or IMC
PSC @ 2400 7-11-7-1T @ 1.9v, 2500 or 2600 8-12-8 no POST
http://img6.imageshack.us/img6/9479/24007117.jpg
3770K + MVE could do 2500 7-11-7 and 2600 8-12-8
BBSE @ 2400 8-11-7-2T @ 1.9v, 1T or 2500 not POST
http://img844.imageshack.us/img844/3...008117212t.jpg
3770K + MVE could do 2500 8-11-7
Also, noticed that ASUS doesn't included LucidLogix Virtu app in their MVIE package and no Thunderbolt port as compared to MVE. You have to pay for the latest Lucid app or use the older available at MVE download support website
Looks like they change the TB port to header/connector at the bottom of the board.
On MVE:
http://www.guru3d.com/miraserver/ima...r/IMG_6654.jpg
The MVIE is a smaller board as compared to previous Extreme's.
MVIE-Z: Extended ATX: 12 inch x 10.6 inch ( 30.5 cm x 26.9 cm )
MVE: Extended ATX: 12.0 inch x 10.7 inch ( 30.5 cm x 27.2 cm )
MVIE: ATX: 12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Smaller width means on multi graphics cards setup it is gonna be harder to push in and pull out the SATA cables since the cards will cover SATA ports.
I think, it could be IMC...I tested 2 chips, one ES and one retail. Reatils is worse at IMC with the same kits (around 100-120 MHz).
@Raja@ASUS:
Asus Z87-Pro BIOS 1007 BUG
When you have Gemalto USB smart card reader connected to USB 3.0 port on the board backplate and a Gemalto .NET smart card inserted the system hangs at POST and won't continue until smart card is removed from the reader. If you remove the card it continues with booting.
Please fix.
@Raja@ASUS:
Other board manufacturers allow disabling Intel AMT in BIOS.Quote:
Originally Posted by Intel Corporation
Please provide a BIOS option to disable Intel AMT on Z87 boards.
Such feature doesn't make sense on an enthusiast/overclocker board anyway.
Pretty pleased with the Z87 Pro (nice bios )-can someone point me to latest ,greatest betas ,Thank you
I was having trouble installing XP on previous-original bioses the board came with ,any idea (IDE native or legacy same results) ?
Latest greatest beats? 1007 is the latest UEFI build if that's what you mean..
@ Raja,sorry ..I meant beta bioses ,probably jumped the gun since this motherboards just came out,I figured you would post them here in "Official Support" thread
I apologize for the typo
You are correct, if I have new builds I will post them here. I don't have any yet, which is why nothing has been posted yet :)
latest build is 3009
Same as 1007 but with multi core enhanced enabled by default. :-)
no Problem but tell the users that 3009 is the latest NOT 1007
thx
Nope they both came out cos some people wanted MCE enabled by default and some didnt. So nothing to tell on what is latest. This has nothing to do with release date and everything to do with the difference between the two builds being MCE only at stock. Going by the word latest implies the timeline is relevant when its not.Thanks.
thats not my mind sorry Raja
when a user asking me whats the latest bios i tell 3009
you have the great Option to work by asus and see your internal bios changelogs i see them NOT
so i see a upper build then 1007 nothing more
the the latest bios for me and all others are 3009
THX
This Gryphon Z87 looks like it was made for me. I love high quality parts and mATX. However, I would like to have the upgraded sound. Hoping for that next time. I'm currently running the V Gene because of this.
You were the one that asked me to say latest and I told you what it was. If you choose to say latest regardless that's up to you :-)
To clarify my position:I'm not going to tell users to flash a build just for MCE at default. Thanks for the feedback anyway. Take care.
once again
for me as an non asus worker the latest bios is 3009
why??
the build date is newer then 1007 and the build number is higher then 1007
Point!!
what changes bios 3009 has only ASUS knows and for me as an normal user 3009 is latest
Point
hope you understand my mind
I don't, but let's move on from this. Thanks.
Raja - my asus utility says my 4670K is priming at 30 degrees .... is this monitoring the wrong temp? Or is it a temp sensor in the socket?
I think you should take note of the previous post just above your last post - this really seems to be a non issue.
On the other side of the coin it would be nice if Asus always posted a complete changelog for each bios release so that we all know
relevant info. Keep pestering Raja on this issue is pointless - he is a busy person, who no doubt has more people to help than time available.
Hero 4X4GB DDR3 3000
http://img197.imageshack.us/img197/9...nshot006ef.png
Uploaded with ImageShack.us
