i wanna push it a little bit further... but i must change thermal compound under IHS ;)
careful i see ppl puting the CPU over a flat table and start cutting THATS NOT RIGHT you should grab CPU with your hands and cut corners and all there with your hands so its flexible and you dont hurt PCB, this is the best mode after 9 delid i did
What batch is it ?
mmm 5Ghz haswell not bad results :up:
Some run with MSI Mpower Max under WC:
SuperPI 32MB 5GHz 1.325Vcore 4c8t
http://img23.imageshack.us/img23/426...25ghz1325v.jpg
Wprimes 4.8GHz 1.235Vcore
http://img28.imageshack.us/img28/208...48ghz1223v.jpg
3dMark 06 4.8GHz 1.235Vcore
http://img824.imageshack.us/img824/5...48ghz1223v.jpg
BR
Nacho
give batch nacho! haha
and go coldddd
The batch number is L307B156, i try 5 of the same batch, and this is the only goodone Vivi.
guys, any idea what is the safe limit for CPU RING Voltage? i've just checked voltage measurement points and found out that with CPU ratio x46 and Uncore ratio x46/ 1.2Vcore CPU RING (auto) is at 1.344V!!! (default is 1.05V...)
CPU VRIN is at 1.744V so it didn't change much, but RING is just mad...
Good luck Vivi :up:
Any information for L312B334 ?
Becareful with vttddr and vccin.
One proc dead. Two more to go, got a gaygay oc to test as need to check where the prob
is.
do you guys have speed step on?
Just did a quick super pi run on 32m
47x on 1.28v
will push for further when I get home from work.
using an h100i
not if you grab CPU on your hands most ppl put it over a flat surface and then push the razor and that how PCB is damaged...u need to grab always CPU on your hands so you curve it as needed i delided 9 chips with not a single mark on it look
http://www.xtremesystems.org/forums/...results/page29
Only @ 4.2 Ghz and core's hitting 80 on water! Yep. It needs to be delidded.
http://img.photobucket.com/albums/v2...psc40fb6a5.png
