Originally Posted by
Raja@ASUS
I understand what you are saying, but there is not always value in having timings adjusted so far even from a raw performance perspective. It depends what you deem valuable. It may not be tRC that is causing the instability anyways, so that is why I said we will check first and it is also likely why it may have been left out due to not adding anything. If the margin between needing a high tRC versus a slightly lower clock frequency are not large enough, the additional delay to tRC is of no real benefit. :)
