Testing Results :
XSPC
RASA water block - PASS
RS240 - PASS
X20 750 Pump & Reservoir combo - FAIL ***
Single Slot Pump & Reservoir combo - FAIL ***
Laing DDC 200ml Reservoir Pump Top : Plexi - PASS
Single 5.25″ Bay Reservoir - PASS -=Out standing effect's=-
Duel 5.25″ Bay Reservoir - PASS -=Out standing effect's=-
Standing for 1 week - Working
Constant flow low rate - Working
Constant flow fast rate - Working
Long term testing - On going
Temperature + 2.5 to 3c (stress testing under Prime 95) after 7 days of running.
(no build up in block found)
*** Bay reservoirs with pump cause build up between the pump and the reservoir were the liquid is standing and there is no flow.
Watercool
Heat Killer
With Restriction Plate - FAIL
Standing for 1 week - Fail
Constant flow fast rate - Fail
Temperature + 8 to 10c
Long term Testing - Fail
(Build up in block found)
With out Restriction Plate - PASS
Temperature + 2.8 to 4c
(No Build up in block found)
EK
Supreme LT AMD Acetal AMR3 - PASS
Temperature + 3.1 to 4.3c
Long term testing - on going
Phobya
DC12-400 12 Volt Pump - PASS
Balancer 150 Black Nickel - PASS -=Out standing effect's=-
S.1366 / 1156 Water Block - PASS
G-Changer 240 - PASS
Full testing not complete yet - Updates more often over at
http://www.specialtechforums.co.uk/v...Range-work-log
