Shazza, Please don't tell me you got your edjumication from NaeKuh's alma mater? I dipped them in Tequila!
Get one, and a toast to you too Rich.:D:bounces:
I can't see last tree pictures :( Please reupload.
Time for a lot of block augmentation, kind of like breast.........never mind.
We start with this...
http://img.photobucket.com/albums/v4...d/DSC03886.jpg
Sorry, no pics of the surgery, we have seen naked nvidia cards. The patient afterwords...
http://img.photobucket.com/albums/v4...d/DSC03894.jpg
The nickel looks green due the fact that I took this pic in my backyard and all of the green reflected. Additionally, I did not place the backs because I will be changing all of the screws to black. Yes, another tear down is on the way.
http://img.photobucket.com/albums/v4...d/DSC03896.jpg
http://img.photobucket.com/albums/v4...d/DSC03895.jpg
http://img.photobucket.com/albums/v4...d/DSC03897.jpg
I will also replace the top hex heads on the AQ 580's with black hex heads. I must say that Aqua has found a superior mounting solution with their built in stand-offs and ease of installation overall.
The Twinconnect is outstanding, extremely sturdy and well thought out.
Shoggy, you guys need to design a case!
Cheers!
Very beautiful blocks for sure.
+1 for Aqua Blocks. I love mine and love any build with them!
These blocks look better than on the pics on Aqua's site! Makes me regret not getting these! :D
Too bad full nickel Aqua's blocks aren't available for every single card.
Thanks, I like them too.
Some more of Martin's brilliant work...
Attachment 116167
SATA breakout cable....
Attachment 116168
Attachment 116169
Continuing with my Madness theme, I am ditching the case and getting a new one. :eek:
[QUOTE=theseeker;4856603
RED; Pump-250 Res-GPU-MB-Rad
YELLOW; Pump-CPU-Ram-400 Res-Rad
[/QUOTE]
I have to ask...
This is the first time I see a loop where the pump goes before the res. So as far as I undrstand you will be pushing water to the res and then It will go out of it to the block that comes next to it, isn't it?
If am I right, how that works?
Thanks!
Which case are you planning to get? Could try 800D or something made by Lian-Li.
I do things a bit differently than most people. I usually go straight from the pump to the blocks, to the Res and then to the Rad. I have found that H20 temps equalize so the loop order does not really matter. I do know that the pump or pumps should be at the lowest mounting position available.
Send a PM if you want more information.
Zal, I am looking at a Case Labs TH10 with the pedestal. I need some room!
Madness!!!! Ever changing parts. Looks like you're still having fun.
The new case has been ordered and with a little luck, it will be here by the end of next week!
CaseLabs TH10 in white with the pedestal and a number of accessories.
I will post an in depth review once I receive it.
Here is the list;
Case – TH10:
Color – White:
ATX Layout – Reverse:
MB Door – XL Window Upgrade
PSU Door – Std Ventilated:
Top Cover – Std Ventilated:
Front I/O Panel – None:
MB Back Plate – Hex Mesh:
HDD Cage Assy – Std:
Extended Pedestal Assy (White):
MAC-101 Std HDD Cage Assy:
MAC-107 Caster Kit:
MAC-113 Fan Mount: 2
MAC-116 Small Attachment Plate:
MAC-118 Large Attachment Plate:
MAC-123 PSU Support Brkt:
MAC-124 SSD Mount: 3
MAC-129 Bottom Accessory Mount – Double: 2
MAC-152 Vertical Accessory Mount XL: 2
MAC-155 480 Radiator Side Mount: 2
Well I have to say good choice on going with the CaseLabs, I've heard nothing but good things on them.
ooooh! cant wait!!!! :D
Looking forward to seeing the white one. Can you try to take some shots for the worklog of assembling the case, and the accessories? The cases look very nice but cant find too many "putting together" pics...
I will, just remember that I tend to go overboard!
Now I would appreciate your opinion regarding some colors. My theme is red, white and black and I will be changing the hex head colors on the Aquagrafix cards.
The way it comes....
All white.....
http://img.photobucket.com/albums/v4...03895white.jpg
All black....
http://img.photobucket.com/albums/v4...SC03895BLK.jpg
All red.....
http://img.photobucket.com/albums/v4...SC03895Red.jpg
And a couple of combos..............
http://img.photobucket.com/albums/v4...3895blkwht.jpg
http://img.photobucket.com/albums/v4...SC03895WBR.jpg
I am leaning towards black screws and possibly powdercoating the top covers in white.
Any thoughts?
Black screws and leave the natural metal finish. It looks spectacular!
I agree, black definitely looks best :D!
