Please do, Its a really neat setup but I just have some concerns that some of the longer runs of tubing will pose a problem once the water is in them and everything is "flowing".
Great job so far! :up:
Well here u have it the loop is up and running
Time for a small Video Update ^^
On Monday i received a nice package from highflow, thank u :p
in the package was 2 bottles of Fezer One UV blue + some leds and power cables.
Only forgot to take some pictures of it.
Yesterday i did my first test run. To see is there where any leaks in the pipes of fittings.
And luckily there where zero leaks to spot.
To filling of the loop only though 15min and all the big air bubbles where gone on some small bubbles left in the GPU blocks
hope u like the movie ^^
http://i1187.photobucket.com/albums/...h_SDC10345.jpg
My first thought where that Fezer One was to dark but when i saw it in my loop it was perfect
Sponsored by Highflow
http://i1187.photobucket.com/albums/...n-s/header.png
Completed Builds
Project Umbrella
Black Obsession
Incredible, thx for the video, i want to see more :D
thanks man
Made a night shot of the pc yesterday
http://i1187.photobucket.com/albums/...SDC10351-1.jpg
http://i1187.photobucket.com/albums/...SDC10352-1.jpg
I only need to find something for the GPU's to light them up
It looks outstanding!
I see that early on in the build you painted the PSU's cooling fan white. Was the paint job successful? I have attempted on three occasions to paint fans and every single time they ended up in the trash because of how easily they get out of balance. I've tried both spray paint for plastic as well as high end automotive paint shot through my HVLP detail spray gun. And I'm no hack when it comes to painting either.
I had less vibration after using my HVLP gun, so I'm guessing that even though I've got it dialed way back, i'm still laying down too much paint per coat. Perhaps i just need a smaller needle for my HVLP gun.
Super smexy dude.... JIMP'd!
oww.. great work, congratulations brow
thanks
Well after the fan was dry from the paint i tested the fan and is was spinning i didn't really check the vibrations of it.
But when i check it now i cant feel any vibes coming from from the fan but i already installed the fan back in to the PSU house
Thanks ^^
This is truly an epic build. I am envious of how it is turning out.
I have a few questions.
1. You said that you would need more fittings than what you currently have to make the connection from the GPU and the CPU. Perhaps with a 45° fittings at the GPU could aline the fitting so a single 90° copper pipe may go from the CPU to the GPU.
2. What type of copper tubing did you use? K, L, or M?
3. What method did you use to bend the copper pipe?
moar pics!
1 the fitting would be perfect but i kinda like it how it is now. i installed windows last week on it to see everything is working, and is the aquearo5 says that the pump is doing 120l/h at full speed
2 type of copper tubing i don't really know i kno that the OD is 12mm and fits perfect in the bitspower multi link.
3 a normal pipe bender
http://i1187.photobucket.com/albums/...e/SDC10679.jpg
With the pc online now i can game so there will be a small delay for the next update ^^
How would you keep the copper from oxidizing if you wanted to keep that look? The only thing I can think of would be some sort of clear coat paint.
Wow just outstanding!
The will get a coat of nikkel like the waterblocks
Thanks Man
So here we are again
First of all i want to thanks Pascal from Casemodparts.nl for helping me out with the wonderful work and great service of making my parts at his work. Thanks you
Now time for a Update
After my holiday in Portugal i thought that it would be nice to make a own logo for the case.
Something simple but still very nice to look at. So i started to draw some logo's. After a few logo's i finally made 1 i really liked and would fit perfect with the case.
Here is the final drawing from the logo for project white.
http://i1187.photobucket.com/albums/.../LogoWhite.png
When that was done i only had to make a new front plate for my TJ07 with the logo. + one with highflow logo
http://i1187.photobucket.com/albums/...ishedwhite.png
After it was done i mailed it all to Pascal so he could make the covers at his work.
With the end result .
Highflow front
http://i1187.photobucket.com/albums/.../SDC103542.jpg
http://i1187.photobucket.com/albums/.../SDC103552.jpg
http://i1187.photobucket.com/albums/...e/SDC10348.jpg
White front
http://i1187.photobucket.com/albums/.../SDC103522.jpg
http://i1187.photobucket.com/albums/.../SDC103532.jpg
http://i1187.photobucket.com/albums/...e/SDC10347.jpg
GPU Covers
http://i1187.photobucket.com/albums/...e/SDC10346.jpg
http://i1187.photobucket.com/albums/...SDC10345-1.jpg
http://i1187.photobucket.com/albums/...SDC10343-1.jpg
http://i1187.photobucket.com/albums/...SDC10344-1.jpg
They will be placed here
http://i1187.photobucket.com/albums/...e/SDC10349.jpg
http://i1187.photobucket.com/albums/...e/SDC10350.jpg
Now my problem for putting some leds on the GPU is solved at once i just place the leds under the CPU cover to light up the cards.
So now back to modding and make some brackets to hold all this stuff on place.
Completed Builds
Project Umbrella
Black Obsession
coolant needs to be white :D
Already this is so perfect! I think more with white fluid that would be even more perfect!
Looks great. I'll be wathing this!
Small update
GPU Covers are ready to be painted.
I finished off the top cover with some plexi and a led.
Not much to tell about then showing u guys some pictures ^^
Started with plexi by cutting the right shape that i needed the i frosted 1 side of it.
http://i1187.photobucket.com/albums/...SDC10369-1.jpg
got a few stickers from work with me very handy ^^
http://i1187.photobucket.com/albums/...SDC10370-1.jpg
On the back side of the sticker is some kind of aluminum foil helps spreading the light true the plexi and also helps isolating the light that it docent shine true the back
http://i1187.photobucket.com/albums/...SDC10371-1.jpg
http://i1187.photobucket.com/albums/...SDC10372-1.jpg
http://i1187.photobucket.com/albums/...SDC10373-1.jpg
Led in it
http://i1187.photobucket.com/albums/...SDC10374-1.jpg
Front plate over it.
http://i1187.photobucket.com/albums/...SDC10376-1.jpg
Dont mind the color it changes all the time depends on the water temp
Then doing it all over again for the GPU cover.
http://i1187.photobucket.com/albums/...SDC10380-1.jpg
http://i1187.photobucket.com/albums/...SDC10379-1.jpg
http://i1187.photobucket.com/albums/...SDC10381-1.jpg
Mounted it on the GPU
http://i1187.photobucket.com/albums/...SDC10368-1.jpg
Connected the led on the motherboard (HDD activity)
http://i1187.photobucket.com/albums/...SDC10364-1.jpg
Short movie of the light :p (click on the picture)
http://i1187.photobucket.com/albums/...SDC10367-1.jpg
Cya next time.
GPU covers are ready and mounted on the GPU :p
http://i1187.photobucket.com/albums/...SDC10385-1.jpg
http://i1187.photobucket.com/albums/...SDC10386-1.jpg
And a very nice night shot of the white logo.
http://i1187.photobucket.com/albums/...e/SDC10382.jpg
The up coming weeks well be very busy. To get the PC ready for Gamescom:D
There is still a lot to do like. Making window in site panel painting the case installing extra leds + some other random thing i forgot to tell u guys.
All this needs to be done before 18 of August.
If i can arrange transport to Gamescom i will everything in my power to get the case ready to show it on Gamescom
wow what an amazing worklog!
looks great.. but why copper tubing?
Update
This weekend i disassemble the case so u could get the case ready for the painter
Empty Case
http://i1187.photobucket.com/albums/...e/SDC10405.jpg
As result a room full with hardware an WC parts
http://i1187.photobucket.com/albums/...e/SDC10406.jpg
http://i1187.photobucket.com/albums/...e/SDC10407.jpg
http://i1187.photobucket.com/albums/...e/SDC10408.jpg
Cleaning every part of the loop
http://i1187.photobucket.com/albums/...e/SDC10409.jpg
The case still needed a window
http://i1187.photobucket.com/albums/...e/SDC10414.jpg
http://i1187.photobucket.com/albums/...e/SDC10415.jpg
Yesterday the case was moved to the painter. he said that the case would be done this week :D
I also have to do a little tweaks on the GPU's installing some leds + mounting the cover plates
http://i1187.photobucket.com/albums/...e/SDC10417.jpg
Connected the 2 card together and placed them back on the motherboard.
http://i1187.photobucket.com/albums/...e/SDC10418.jpg
http://i1187.photobucket.com/albums/...e/SDC10419.jpg
I also tried something new with the power cables of the GPU.
http://i1187.photobucket.com/albums/...e/SDC10411.jpg
http://i1187.photobucket.com/albums/...SDC10421-1.jpg
Lights on !!
http://i1187.photobucket.com/albums/...SDC10420-1.jpg
And the end result of all this bring a very messy room :p
