Noooo don't kill them :(Quote:
Originally posted by hotwheelz
So ill have a Shuttle AN50R
In Bios i set the vdimm to 2,9v and then with the VR up to 3,1v
when i measure the vdimm its jumping from 3,1 up to 3,8v
:eek:
and my two A64 (3200+ / 3400+) wont go higher then 2500mhz with mach2 so ill killed them!:stick: :(
Set your VDDR in bios to 'auto', using your trimmers increase/decrease your voltage running through your ram.
If you want a stable VMod instead of using the 50K trimmer, just use either 2x 1K 15 turns, or a 1K 15 turn VR + 1k resistor in conjunction, the mod will be stable, and not to mention save you time from having to turn your VR 50 million times ;).
Joe, to be honest if you think my RMA'ing "botched" parts is "fraud", "dishonest", and "not reasonable", then you my friend are in the wrong place. I understand your point of view, and I have no quarrels with it. But you also need to remember that no matter how wrong or right you think something is, its still mainly your thought. You trying to either become a catalyst in changing my views or you trying to 'enlighten' me is not going to change my actions. In my mind I find my cause just, because I am trying to get the most performance out of a product any given manufactuer puts out and until they (the manufacturer's) start putting out more durable products I won't have any reason to stop what I'm doing.
That will be the end of that topic for me, I will no longer respond to this thread because we are here to OC not belittle one another :toast: .
