Do u play BF BC2?
Edit: U edited before my reply... lol
played bfbc2 on 5970 @ 11.1beta and there's still flickering and it still crashed, twice. However, the slow alt-tabs seem less frequent?
No crashes here but, annoying loading SLOW fps...
Alt + Tab seems to be ok.
i hope these drivers fix my issues with legue of legends im kinda sad i decided to switch to amd :(
There're no issue with LoL. I think people tend to do bizarre things with their rigs, that's the only explanation.
I played 3 hours of BFBC2 yesterday. At first it crashed out twice within 20-30 mins. I turned OFF punkbuster and not a single crashe for the next 2 hours. This was in single player and it seems the crashes are due to PB disconnecting for some reason.
I also had some minor texture flickering but then I set ingame and ccc vsync to both on, it went away. Originally I had ingame vsync OFF, but CCC on, and there may have been some conflicts - ingame was overriding ccc for me.
BFBC2 with everything maxed out at 1920x1080 8xAA, 16xAF, HBAO on... no lag in single player whatsoever with these drivers and CFX.
11.1 and 11.1a drivers are officially out, get them here.
Someone post results up using 11.1a hotfix drivers pweeez
as u wish
6970 def
http://img337.imageshack.us/img337/9513/5ghu.jpg
Thanks gaul nice single 6970 score, What were previous scores using 10.12?
I saw a bigger improvement:
10.12a RC3
http://paulyd.co.uk/oz/6970%203dmark%20vantage%20+.jpg
11.1a Hotfix
http://paulyd.co.uk/oz/6970%203dmark...01025_1475.jpg
I wonder if in the next hotfix we will see GPU test 2 go up 5-10fps as well :rofl:
wow nice 966pt difference.. But then again your clocks are alot higher.. Seem like these drivers arent that good like AMD are hyping them up to be -.-
Huh? Clocks are exactly the same, apart from the memory which is 20mhz LOWER in the 11.1a result. Edit: oh, or are u comparing my result to gauls? Yeah i'm sure sandy bridge at 5ghz will bring that gpu score up a bit.
cat 11.1 whql ( lower score ), but u got Open_CL
http://img171.imageshack.us/img171/7704/whql.jpg
Yeah i thought u meant that, but still i don't see the reason for mentioning it. I know my clocks are much higher, all i was showing was that 11.1a is about 1000 points better compared to the older drivers :)
@Gaul, what's the benefit for open cl in the whql? I thought we already had it? :confused:
i don't know, perhaps on software ?? :shrug:
vantage and 3DM 2011 doesn't need Open_CL
@ oztopher, johnny87au = max i can touch with STOCK HSF, 100 % FAN.............ha ha ha LOUD HERE !!!
with cat 26jan 2011
http://img213.imageshack.us/img213/9254/vantagew.jpg
anyway
6950 @ 950/1450 can touch 6970 def :up:
http://img689.imageshack.us/img689/5321/69509501450.jpg
You can get 11.1 OpenCL driver here. ;)
Just install that after installing 11.1a.
Just tested these drivers and still no fix for my 3rd screen defaulting to 640x480 . need to disable third monitor again ..
Hmm, thats odd, seems these drivers have issues with the 6000 series cards, and crossfire/eyefinity. They work fine with my 3 5830's in eyefinity.....
i just tried to install this 11-1 64bit for my main rig and it fked my pc. i tried 4 times with results as follows: 1unsafe program "ultradefrggr" being found by norton 2011 in hydravision install folder, 1 bsod, and 3 unresponsive computer freezes.
out of the 4 times it actually installed 2 times. i opened CCC up and tried to reset my gpu clocks. it was at 625/1000 and i wanted it at 600. CCC auto moved it to 500/750 and when i tried to change it, it killed my computer, twice. restarted desktop and as soon as ccc opened in the task bar it killed my pc again, had to go into safe mode and restore. in the proccess of backing up to 10-4
what the hell is up with 11-1?:mad:
http://securityresponse.symantec.com...112113-1147-99
found in file c:\program files (x86)\ati technologies\hydravision\hydradmh.dll
so my 5970 on 30+24in screens = unplayable bfbc2 on 11.1 official. I'm just going to quit playing that :banana::banana::banana::banana:ty game, it never :banana::banana::banana::banana:ing works.
