wizard1238
I suspect you are the man behind those DDC repair kits or very close to its production.;)
We need some clarification on whether
this kit is suitable for DDC3.x pump repair. The coil wire length problem can be easily solved. But is there something else that should be taken into consideration?
There are some reports that this "blue" kit does not work with DDC3.x pumps - controller get burned or even if it works, the overheat safety feature restarts the pumps every 3 sec. Not sure what revision it was, the first one or the second one (with pre-soldered elements).
