Dinos arent the gtx2's you mentioned PSC chips or is that the gtx4?? Mine cant hit cas7 @2k+
Vtt won't help its something else. Probably not the right thread to do x58 troublehsooting jump in ud9 thread and a few guys should help ill swing by too
Best I could do today. No hyper so mem wont go tighter and I cant use the next divider bc it cant do the speed.
http://images.hardwarecanucks.com/im...7/OC/32m-7.png
hey, im have done this so fare, but we still benching :)
http://hwbot.org/signature.img?iid=5...se&iehack=.jpg
1.72v, yikes be careful m8, these chips are fairly fragile
How about 2500K.:D
Not a nice chip can't reach 5.5G.:shrug:
Using P8P67 Pro, would have buy Asrock Extreme4 if I knew they will rise their Vcore to 1.7V.
Attachment 111429
Attachment 111430
A bit late, but I had to find good rams first buddy ;)
So here's my ~ time matching, I thought you would'nt mind for 00.001s :D :
http://lh6.ggpht.com/_iiaFLkpoRZ4/TT.../screen006.jpg
http://picasaweb.google.com/11194975...19672699659170
And here's my 32M; need to work more on it :
http://lh6.ggpht.com/_iiaFLkpoRZ4/TT...05s250_32m.jpg
http://picasaweb.google.com/11194975...19677952718546
Bye
p€p|n0r@ng
My take on 32M:
http://www.teampclab.pl/wyniki/i7_26...m_6_08_547.png
Most can't do over 5 gig with a 2500K, consider yourself lucky.
Thats like a top 5 chip on hwbot..........
Mines retarded, it primes at its max valid.........
http://chew.ln2cooling.com/P67A-UD7/7.jpg
Here is a 2500K Rosty pushed a bit
http://odoc.dk/files/overclocking/re.../32m620219.jpg
:clap: rosty
I am dragging my feet about sandy bridge. the 2500k is $179 at microcenter and then a jump to 2600k is 300.00.
with no real scale with xtreme cooling its been holding me back on a purchase. chew and I had a discussion about how this will level the playing field and this is going to be really competitive since a lot more people have h20 than ln2/dice. I just want the high i get from ln2 and seeing it scale. i miss the clarksdale days.
Still untuned win7 here, nice gains to be had tuning subs only.
No subs.
http://chew.ln2cooling.com/P67A-UD4P/Dinos%20right.jpg
With subs.
Could be wrong but with 32m translation from 7 to XP should be on par with dino.
http://chew.ln2cooling.com/P67A-UD7/4%20cores.jpg
Also tested core variation and it seems to me no difference other than normal bench run variable.........
3 cores
http://chew.ln2cooling.com/P67A-UD7/3%20cores.jpg
2 cores
http://chew.ln2cooling.com/P67A-UD7/2%20cores.jpg
He doesn't need hypers..........properly tuned PSC will run neck and neck.
Compare to above,
http://chew.ln2cooling.com/P67A-UD7/hypers.jpg
And one from me. My chip is maxed thear.:)
http://www.hwbox.gr/images/imagehost...c1c332d0af.jpg
OK dino's ready to play err get my ass handed to me but i'm curious how much effec the platform really has.
Load up an Xp tommorow.
http://chew.ln2cooling.com/P67A-UD7/Hypers%20tuned.jpg
After seeing more and more result with 2500k i realise mine is a rare one :D Here is some s-pi 1M,unfortunetly chip has a wall,it can do 5540 with 1.48 but it wont scale a mhz more with 1.52 for example.Will have to wait for improved asrock bios...
http://img15.imageshack.us/img15/4357/6704.th.jpg
Uploaded with ImageShack.us
Chew: your chip can go higher than 5000 MHz? How much voltages for PRIME and your 5 GHz?:)
