:shocked: :up:
Are the shown RAM timings correct? That would be wow :up:
Yes , it same DDR3 that i used here : http://www.xtremesystems.org/forums/...d.php?t=264859
wow very nice kit which seems to be perfect for sandy - seems I need to test some more ram ;)
If you would have read my last RAM reviews sof, you wouldnt be surprised :-P
All better PSC based kits can do this with ease.
Got mine today ... L040B165 :D
Hoping for good results, at work on a night shift atm :(
fighting with that last seconds also now...got new ram and that helps quite a bit!
6min 6s 703ms @5558 MHZ RAM 1078 9-10-8-24-1T a supertalent kit...
http://img263.imageshack.us/img263/4...1078cl9.th.png
nice to know supertalent works...wooo
They work for sure better than my old hyper kits from mushkin ;)
but after let's say 3-4 hours the system seems to get unstable with high ram and high mhz near limit and will only work below 5.5....I need to let it rest a bit and next day it goes 5550+ cpu 2150+ ram again...reminds me a bit of GT ;)
P67A-UD3 F6a. I'm gonna try the hard way this weekend, cascade :D If it fails on me I'll just open lo-hi bypass valve. If it still fails I'll get it under single-stager :D
http://file.si/pfiles/145381/5242_pi32m.PNG
good luck dude!! until now I saw them workin but not scaling under cascade :(
2100 @ Cas 6 nice!
P67A-UD3P F6a beta bios@2600K Batch #L040B225 @5Ghz@vcore 1.45v bios stock cooler@8gb Kingston HyperX Cl 9-9-9-24
http://img266.imageshack.us/f/2600k5...superpi1m.jpg/
:) my first touch with sandy bridge and cheap motherboard :D
max multiplier in bios X58 :D right now thats should do nice numbers with cold like dry ice / Ln2
you already heard of sandy not liking DICE or LN2 for the moment? when you are lucky and have a good watercooling and winter outside you are very often able to max out the chips - a singlestage helps for running some high vcore on benches but it will raise your clocks minimal (1% max - at least for me and some others without somebody showing us some new bios- or hardmod-wuuzaaa ;) )
for the moment I think they are - haven't seen a cpu yet that does more than 100 mhz more compared to air/water. the highest clocks we've seen are on air - pretty sad for the extreme community :(
massive cpu binning on air seems to be everything you need to do to get some top10 scores in pifast and 32m...well I hoped for more after initial testing but for now sandy is badly "hard-walled"... :(
