You guy's really are not having a discussion based on my decision are you? The answer is NO unless you want to send me the funds to cover the board.....I already stated at stock it's extremely warm and that i can't cover cost of board.
While some of you may have gotten a "good" GD70 how many of you had more than 1?
I can raise my hand ;). Can you? Case closed under my testing they can and will blow and i know exactly how to pop them instantly right at boot ;) 4+1 or 24 phase it doesn't matter. A mosfet that doesn't like heat or spiked load is what it is. Adding more doesn't make a diff or have you guys never seen an x58 blow up with XXXX amount of phases.
Moorhen, turbo disable is working fine.
