Originally Posted by
Polizei
Personally, there's one thing about your loop routing that I would change. I would keep it res > pump > radiator > GPU > motherboard like you have it now, but instead, I would then route it CPU > radiator > res. The tubing from motherboard > radiator > CPU just looks... odd and cluttered to me.
I think it would cut out a bunch of tubing for you and make it look cleaner.
I guess to make it clearer, I would:
res > pump > radiator > GPU > motherboard > CPU > radiator > res
instead of your
res > pump > radiator > GPU > motherboard > radiator > CPU > res
