Originally Posted by
davidkozat
Ok I presume that your board sets AHCI when you set your HDDs to Enhance cos Gigabytes mobos call options differently to other boards (donno why lol) but yeah after loading the disc all you gotta type is -v and press enter, the splash screen will go black and white letters will load up and the cpu cores will load and other stuff if it stops or KPs right down the error and type it here, mind you it might load really slow or it might take a while to load as long as the disc keeps spinning you are good :up:, also if you see and option like *DSMOS has arrive it means that you are most likely to have the correct Hardware and it will load correctly. BUT it might stop after that though as I said just keep a look and record what you see on the screen or take a picture of the error it will help greatly :)
