2560x1600 cat 10.8
2560x1600 cat 10.8
HD5770
http://img838.imageshack.us/img838/1999/benchs.jpg
HD5850
http://img690.imageshack.us/img690/3695/4595.jpg
GTX 460
http://img35.imageshack.us/img35/772...3021264053.png
GTX 470
http://img193.imageshack.us/img193/9617/444adsz.jpg
Trifire HD5870
http://img291.imageshack.us/img291/9...s1280x1024.jpg
3WAY SLi GTX 480
http://img687.imageshack.us/img687/1607/avpt.jpg
2560.. show off!! :)
dont have 2560 but heres 1280 for comparo
same 900/1800/2200 as earlier
http://i52.tinypic.com/35174o6.png
Hi, I have a little problem AvP.
When I set resolution to 1440x900 the image isn't centered and/or properly scaled.
With other resolutions it's ok but that is what I want to use.
When this happens with other games I just press "auto image adjusment" monitor buttom and problem is solved but with AvP it doesn't work.
I thought it could be driver's issue so I changed catalyst 10.9 to 10.8 unsuccessfully.
Any suggestion?
Thanks in advance.-
http://img137.imageshack.us/img137/9...g0016rd.th.jpg
PC specs: Q6600@3.2GHz, X48T-DQ6, 4GB DDR3-1600, HD5670
Here is my Gigabyte GTX460 OC :up:
http://img44.imageshack.us/img44/4872/avpg.jpg
stock cooler :up:
http://img213.imageshack.us/img213/3629/68523122.png
Did you have to hardmod it? To bypass the stupid limiter chip... Or did you use a BIOS workaround?
here's mine..... :D
http://img24.imageshack.us/img24/9286/benchie.jpg
@ kaktus1907 = here 4 u'r database
http://img651.imageshack.us/img651/9410/avpz.jpg
is it me or does the 5970 still hold its own???
Where do I donwload the GUI bench application. The links posted in the thread does not seem to work from my side.
stock cooling no mods
http://img255.imageshack.us/img255/7199/75912997.png
I really wish benchmarks would start including min fps as a standard in the output - average fps isn't as important as min for overall smoothness of gameplay.
AvP 1.03 Bench 1920x default, single HD 6850 @ 945|1150, 47.1 FPS avg
http://img59.imageshack.us/img59/9332/avp16850a.jpg
AvP 1.03 Bench 1920x default, HD 5870 Crossfire @ 1000|1275, 111.4 FPS avg
http://img254.imageshack.us/img254/1597/avp2.jpg
One is from my old Ph II 940 rig and two is from my 1055T rig.
