Thank you guys!
The new skin is ready to download, a bit buggy yet, but it's functional.
To download, please visit: http://www.radeonpro.info
Screenshot
http://www.radeonpro.info/Images/rad...verde_skin.jpg
Thank you guys!
Screenshot
Sexy :yepp:
CCC got nothing on RadeonPro :up:
nice program
thanks
Updates
06/24/2010 - Updated build 1.0.7.18
- Added detection of skins failing to load, the program will start with default skin when a skin fails to load
- Added backslash as allowed key for shortcuts
- Fixed CrossfireX tweaks group incorrectly disabled even when CrossfireX is present
- Minor changes to Overclocking feature (trying to fix flickering and high CPU usage, please report if you had issues with previous builds)
-- Skin updates
--- Verde: Minor bug fixes and internal optimization for better performance
--- Verde: New toolbar for profile tasks replacing previous controls
--- Verde: Back/Forward list fix
06/23/2010 - Updated build 1.0.7.17
- Skin Verde updated: options to rename profile, launch, edit startup parameters and open location are back
06/23/2010 - New build 1.0.7.17
- Minor bug fix in Auto-updater
- Fixed error in Verde skin, when Programs tab is acessed and there is no profiles created yet an error message is shown
06/23/2010 - New build 1.0.7.16
- Fixed Auto-updater not checking installed skins version while checking for updates
I get "Error Saving Settings" when I try to enable the overclocking in Settings/Advanced.
But in the new skin it looks like the overclocking page is always there, enabled or disabled.
Btw, where is that box that identifies the game I ran in the new nVidia looking skin? :shrug:
I'm back to default skin, to much bugs with the nVidia looking one.
But in the last update this happened
Sorry about that, there are issues with large fonts I'm going to address as soon the problem gets more stable.
The latest version has lots of updates that should fix some of issues you're getting with Verde skin, did you tried it?
Thanks.
Yes, this happened as soon as I changed the skin.
-- Begin Report----------
AppProfiles.dll Ver 1, 0, 0, 0
atimgpud.dll
exec.exe Ver 1.0.0.0
ICSharpCode.SharpZipLib.dll Ver 0.85.5
Localization.dll Ver 1.0.0.0
RadeonPro.exe Ver 1.0.7.21
RadeonProSupport.exe Ver 1.0.2.2
raphook.dll
RPSupport.dll Ver 1.0.6.0
Start.exe Ver 1.0.3.0
unins000.exe
Object reference not set to an instance of an object.
at RadeonPro.BaseForm.OnDoUpdateUILabels(ControlColle ction parent)
at RadeonPro.BaseForm.OnUpdateUILabels(ControlCollect ion parent)
at RadeonPro.BaseForm.LoadConfig()
at RadeonPro.BaseForm.BaseForm_Load(Object sender, EventArgs ev)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Mes sage& m)
at System.Windows.Forms.ContainerControl.WndProc(Mess age& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at RadeonPro.BaseForm.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
CpuCores: 4
Installed drivers: aticfx64.dll, aticfx64.dll, aticfx64.dll, aticfx32, aticfx32, aticfx32, atiumd64.dll, atidxx64.dll, atidxx64.dll, atiumdag, atidxx32, atidxx32, atiumdva, atiumd6a.cap, atitmm64.dll
Main Device Registry Key: System\ControlSet001\Control\Video\{14920DFC-D129-479F-BD4E-3CB28284451A}\0000
Main Display Adapter: ATI Radeon HD 5700 Series
PNPDeviceID: PCI\VEN_1002&DEV_68B8&SUBSYS_03321043&REV_00\4&113 C73B2&0&0018
GPU: ATI Radeon HD 5700 Series 1024 MB
Video Processor: ATI display adapter (0x68B8)
-- End Report ------------
Ah ok. Sounds good :)
Is it possible to add a feature of locking a refresh rate for global and per profile?
There are some games that for some reason like to change the 60hz refresh rate I set in catalyst and I have to use a refresh lock application to lock it at 60hz or I get black screen on my TV :(
Are there any plans to adding forced tripple-buffering in D3D?
EDIT: *Facepalm* I found it!
Lots of updates since the last time I've updated this topic :shocked:
Updates
07/07/2010 - New build 1.0.7.35
- Fixed: start parameters not saved in backup in previous versions
- Fixed: Favorites and Recently played lists are now kept between sessions
- Added: New Profile Wizard can now save graphics settings to be used when the Wizard is opened again
- Enhanced: New Profile Wizard can now configure almost all Profile settings
07/04/2010 - New build 1.0.7.34
- Added: Add New Profile Wizard
- Fixed: Jumplist shortcuts stops working after some time
-- Skin updates
--- Verde
---- Fixed: CFAA Edge Detect shows invalid option when profile is switched from another one that use another AA filter method
- Known issues:
-- Favorites and Recently played items in Jumplist are not being kept between sessions, it'll be fixed in a future build.
07/03/2010 - New build 1.0.7.33
- Changed: small change in registry key
07/03/2010 - New build 1.0.7.32
- Fixed: rare silent crash after exiting game due to a cross-thread issue causing 3D settings to remain unrestored
- Fixed: Jumplist's Recently played and Favorites not working on previous builds
- Fixed: Recently played and Favorites items in Jumplist don't open games if RadeonPro is not running
- Changed: registry key used to update Catalyst settings reverted to the one used by build 1.0.7.30 and older versions
-- Skin updates
--- All
---- Removed "High Quality AF"
--- Verde
---- Changed: CFAA modes now show effective AA in Anti-Aliasing Level as other skins does
---- Fixed: Global TAA FPS Threshold and Texture LOD list items showing as "Use global setting" when they must show their values even when equals to zero
---- Fixed: Temporal AA cannot be turned Off in Programs tab
07/02/2010 - New build 1.0.7.31
- Fixed: profiles not being saved automatically after change
- Changed: Update list is now shown from newest to oldest
- Changed: registry key used to update Catalyst settings (please report if profiles stops working after updating to this build)
- New: Pin profiles to Jumplist (Windows 7 only)
07/02/2010 - New build 1.0.7.30
07/02/2010 - New build 1.0.7.29
- Fixed: error creating jumplist when RadeonPro is configured to start minimized
- Fixed: start parameters not being saved between sessions
07/02/2010 - New build 1.0.7.28
- New: Windows 7 Jumplists support
- Fixed: Triggers not activating main profile
- Fixed: profile items checkboxes get checked after switching from Global scope to Profile scope by clicking on profile list item
- Fixed: Restored profiles not added to list on skin Verde
07/01/2010 - Updated build 1.0.7.27
-- Skin updates
--- Fixed: toolbar button for adding new profile is not enabled when there isn't profiles created before starting the program
07/01/2010 - New build 1.0.7.27
- Fixed: options not selectable after switching from Global to Profile scope
- Fixed: sliders in Advanced tab are changeable when no scope is selected whereas they should be disabled
06/30/2010 - New build 1.0.7.26
- Fixed: triggers showing only filename in somes cases
-- Skin updates
--- All except Verde: Catalyst AI mode got hidden due to a reallocation bug
06/30/2010 - New build 1.0.7.25
- Fixed: crash when executable is in root directory
-- Skin updates
--- All except Verde: re-added profile list columns width saved between sessions
--- Verde: Added LOD and TAA FPS Threshold control in profiles to be controllable by global setting
06/30/2010 - New build 1.0.7.24
- Fixed: bugs in global/profile options not clickable in some cases
- Fixed: profile settings not being applied when video registry key is not standard (e.g. don't use UMD sub-key)
06/30/2010 - New build 1.0.7.23
- New: logic to show RadeonPro window when it's executed but is already running on background
- Fixed: minor bug in auto-updater
- Fixed: messages being show while converting profiles to new schema
-- Skin updates
--- Verde: Fixed AA/AF Application controlled cannot be selected
--- Tiny: dropped support for a while, it won't be updated for a few builds until some internal changes are completed
06/29/2010 - New build 1.0.7.22
- Changed: profile activation schema in order to allow different profiles for games that share the same executable name (i.e. Source Engine)
- Changed: Video card ID search for Video Spoof feature to use local resources instead of looking for ID at external site
-- Skin updates
--- All: Fixed Lod Adjustment not saving correctly for Global settings
--- Verde: Fixed Enable Wait for vertical refresh and Force Triple-buffering (OpenGL) not saving correct values on Programs tab
--- Verde: Removed header to make up space for profile title
06/28/2010 - New build 1.0.7.21
- Fixed: small bug in Auto-updater
-- Skin updates
--- Verde: Some panels don't get enabled when a profile is selected in some cases
06/28/2010 - New build 1.0.7.20
- Fixed: skins refusing to load
06/28/2010 - New build 1.0.7.19
- Changed: some settings in profile now can be left to be controlled by Global setting
- New updates history dialog. The program will now show a balloon near the tray icon to alert about installed updates
- Minor changes in Skin engine
- Several bug fixes in profile management
- Fixed: restart program feature may fail in some circunstances leaving Support Service stopped
- Fixed: auto updater version checking not working in some cases
-- Skin updates
--- Verde: Tasks tree state (expanded/collapsed items) is now saved between sessions
--- Verde: Fixed toolbar tooltips
--- Verde: Added Profile name on top bar
The new Wizard can configure almost all settings, excluding overclocking and some not much used 3D settings.
http://img.techpowerup.org/100707/Ca...707-002721.jpg
JumpList seems to be working, but I have an issue on my computer, I can see the JumpList on taskbar but cannot see it anymore when the program is pinned on Start menu. If anyone else can see the items in Start Menu and Taskbar, please report.
http://img.techpowerup.org/100707/Ca...707-003033.jpg
Very very nice!:clap:
My only wish is to have an option for forcing the refresh rate. :worship:
Updates
07/07/2010 - New build 1.0.7.36
- Changed: small update to JumpList
Got it working on Start menu too.
http://img.techpowerup.org/100707/Ca...707-102616.jpg
I'm researching about it, but no ETA yet. :(
this looks slick . i would definately recommend changing the picture in your first post to something recent !
Recent, not decent :)
This is awesome. W1z has some serious competition :D
