Thank you, Dingdong555. The water goes in smoothly through SLI fitting + tube installed under the reservoir cap :D
How come you guys don't fill the reservoir to the top?
http://i2.photobucket.com/albums/y30...e/IMG_0283.jpg
http://i2.photobucket.com/albums/y30...e/IMG_0285.jpg
http://i2.photobucket.com/albums/y30...e/IMG_0282.jpg
http://i2.photobucket.com/albums/y30...e/IMG_0281.jpg
http://i2.photobucket.com/albums/y30...e/IMG_0288.jpg
http://i2.photobucket.com/albums/y30...e/IMG_0292.jpg
added UV CCFL´s :D
http://images5.bilddagboken.se/85/_u...2b3d00f5e9.jpg
Most of the cables are now mdpc-X sleeved :D
http://images5.bilddagboken.se/86/_u...bfe856c34c.jpg
http://images5.bilddagboken.se/90/_u...47625626f1.jpg
Dionysus, why so many pictures with the same shot?
very good case
hey all, just got my obsidian, couldn't be happier with it :D ~Just amazing! Ogge, Your build is outstanding :O
http://img683.imageshack.us/img683/5...200012copy.jpg
http://img20.imageshack.us/img20/8699/p6200017c.jpg
http://img408.imageshack.us/img408/6203/p6200014.jpg
Thought I'd share mine
http://digimentis.com/images/ordi/1.jpg
http://digimentis.com/images/ordi/2.jpg
http://digimentis.com/images/ordi/3.jpg
http://digimentis.com/images/ordi/4.jpg
Of course, this is a work in progress. :up:
can you fit a triple in the bottom of an 800D?
You can. With lot of customisation. Like removing non-hotswap disk enclosure, cutting bottom for extra vent intakes and possibly some limits on PSU max length aswell. IIRC rad should be narrow enough too. I've seen even quad in 800D bottom compartment but it involved even more customisation - removing plastic midle wall and fully moving PSU to case side. In general - imho not worth it. Simpliest is to mod top for quad.
Hello
I, too, processed a 800 D bottom and attempted to establish xspc-480 and xspc-240.
http://www.xtremesystems.org/forums/...pictureid=1186
Lots of nice systems in here. I am on the fence with this case. Its between this and a friends Lian Li V2000. Decisions, Decisions.....Input!?!?!
I owned three Rocketfish (Lian Li) cases, and now an 800D. The 800D is an extremely practical design, and it feels to be an even more solid design. The textured powdercoated steel is a better feel than the smooth aluminum interior too. So, my vote is get the 800D.
http://i986.photobucket.com/albums/a...g?t=1278399926
My first build will be doing watercooling later on in the year
For the 800D owners, do you think you can fit a 140 single rad on the 140mm fan in the bottom easily? I know you can remove the cage and put in a double, but I am curious to see if you can fit the 140 rad w/o mods.
Hello Ogge Swe i think the fans are good here is a vid on youtube of them hope it helps you http://www.youtube.com/watch?v=fmu5Sa1w84I
Hi, here is mine :)
Computer :
-Case : Corsair Obsidian 800D
-CPU : Intel Core i7 920 D0 @ 4Ghz
-Mobo : EVGA X58 Classified
-Ram : G.Skill Kit Extreme3 3 x 2 Go PC16000 Trident Series
-GPU : 2x ATI HD5870 Asus Tweak Voltage
-HDD : Western Digital Caviar Black 1To x2 raid0
-PSU : Corsair HX 1kw
WATER :
-Tub 13/19 Tygon
-Full Fezer Company
-WB CPU : Heatkiller 3.0 LT
-WB GPU's : EK-FC58x0 + backplate
-WB CHIPSET : EK-FB EVGA X58 Classified - Acetal
-Pump : Laing 10w @ 18w + top EK
-RADs :
HW Labs Black ICE Radiator GT Stealth 360 XFLOW
HW Labs Black ICE Radiator GT Stealth 240
240 Docmicro
-Res : EK 250 Multi-option
-Fans : Xigmatek XLF-F1253 (120mm) & Xigmatek XLF-F1453 (140mm) + 2 scythes
http://lh3.ggpht.com/_OPPwk2m0VEI/TD...Ia1m9dvc/5.jpg
http://lh5.ggpht.com/_OPPwk2m0VEI/TD...rTPYIPok/2.jpg
http://lh6.ggpht.com/_OPPwk2m0VEI/TD...o0I/s800/3.jpg
http://lh4.ggpht.com/_OPPwk2m0VEI/TD...RFwBbSI4/6.jpg
Other pics : http://picasaweb.google.fr/118191510216945435457/PCApn#
Going to buy that for the 240mm : http://www.mnpctech.com/120mm_custom..._fan_grill.jpg
and that for the PCI's slots : http://www.mnpctech.com/Gold.thumb.screw.jpg
That looks really nice, huRRi, I wish I had the money to create a setup like that nevermind the amount of effort that is needed :( I always envy those with heavily overclocked i7s and 2 oced 5870s in a water loop, it's common to see these setups with the same exact parts on XS especially with the 800D, but not ones that are as colorful as this ;)
This actually gives me some ideas on what colors I would prefer, I thought that going with the standard blue would look great but now I think orange/UV looks a lot better:yepp:
