Originally Posted by
Movieman
Now since there's no PHD behind my name but instead almost 45 years of working out in the real world here's a common sense way to end all these arguments over whose system draws what,when and under what load:
Buy a damned $20.00 Kill-A-Watt like I did, plug into wall, turn on machine, record the numbers on the little LED at idle, run it up to 50% load, record again, run to 100% load, record again. Shut down machine, test next machine, compare numbers, toss in the variable as to machines capabilities, and bingo, decision made..
Cut's right thru everyone's claims and settles all..
Numbers don't lie, marketing depts on all companies at the very least bend the hell out of the facts and quite often lie thru their teeth.
