Haven't uploaded one yet.
I have an old cutdown version somewhere, but I prefer to create a new one again and upload it.
Things got bumpy on my side again, I'm getting hammered these days, so it might take a lil' while fellas.
No probs dude, prio your RL first! :up: thanks for the good work on the OS's :)
I've had no success in changing background :( (XP32)
Is it an image file ( bitmap, jpeg, png ) or an html ( active desktop ) file ?
Btw, anyone with problems running PCMark vantage productivity suite with bill's Windows 7 64bits?
That's weird.
I'll try to check it out as soon as possible.
BenchZoner,
Would you be willing to list or PM me with the tweeks you have made for W7 64-bit? I would like to have a look at which ones may be useful for me.
Your reputation not withstanding:bows:, there is no way I would ever use an OS that "somebody" has been "tweeking" and offering for free on the intraweb. Hell, I wouldnt trust a 'tweeked' OS from my best friend. I'm sure you understand. There are simply too many accounts and transactions taking place for me to allow that sort of trust.:up: But I am certainly willing to make the changes manually if I had a list.
Thanks,
little_scrapper
Sure, why not.
It has to wait a tad though, got 2 high priority reviews to finish first.
Then I'm going to update some of these OS's and add some new ones too ( 2k8 server, PC Mark Vista ) and I'll give you the list of tweaks used ( which windows version are you interested in ? ) [ I'm not using the same tweaks for every version of course ]
Hey Bill did you ever make a xp x64 version?
In the past, but I don't have that ISO anymore.
I will create new ones ( soon hopefully )
Thanks 4 sharing BenchZowner ! Good spirit :up:
Just wanna say thank you BenchZowner for these great iso's!
I am trying your Xp load, i am very excited to see if this works... I will keep you posted....
thanks for the effort! :up:
UPDATE: loaded fine, just had to add a DLL to run easytune 6 on my UD3P, otherwise is a very lite OS
Top Notch :up:
Benchzowner, i saw you said wprime is best in vista x86 for s775. How about what OS is best for superpi for s775? I am working on my q9300/UD3P (just with stock W7 right now. Will be trying your OS's) and have taken the pifast and wprime32 WR's(haven't posted on hwbot yet though), but i am still having a difficult time with superpi.
EDIT: nvm. They all work. Thanks a bunch Benchzowner!
All perfectly work, thanks
Hi Benchzowner very nice of you to give your OS's out, i have tested your win xp in super pi .... in my opinion you have stripped it too much and detrement to spi performance, few things you pulled out which help spi efficiancy :) just a heads up. love your work :)
You are right uncle fester . Better try this XP OS with wprime or 3Ds, it performs better :D It isn't for spi .
Hey Bill I'm trying to get the Vista x86 to work. I've tried redownloading it twice and extract several times from benchzone.com. When it gets to 10% copying files, I get a file error? Any issues on your end or just an isolated occurance?
Everything's ok on my end and for the others too.
Must be an issue on your end, system stability or drive ( maybe your DVD+/-RW is going down ? )
I'm making flash drive installs hmmm maybe the flash drive? All the others worked fine I'll try some other things.
New Windows XP x86 Professional SP3 version uploaded.
Works fine with the latest patches of the 3D Mark series ( fixed the "System info error" ).
For SuperPi, PiFast & wPrime use the older version, works better for those benchmarks.
Windows XP Professional SP3 x86 Xtreme 2 ( 3D Mark Series System Info Error Fixed )
Filelist @ BenchZone:
"Link-List" @ RS:Code:http://www.benchzone.com/Downloads/Temp/WXPx68X2/
Password is:Code:http://rapidshare.com/users/DCL8AT
EnjoyCode:www.benchzone.com
p.s. First post updated
