I.nfraR.ed
Very nice.
Have been trying for 8.So close,yet so far away for me.
I.nfraR.ed
Very nice.
Heres my best run so far,these chips are looking very good dont you think.:)
http://i572.photobucket.com/albums/s...9999999999.jpg
nice 8+:up:
So, this is a only normal voltage with ZThuban, is the same as Denebs, 1.55V 24/7 with AIR is SAFE. With voltage is it about 1.6 for 24/7. For benchmarks u can steps up next +0.05V without fear.
Thanks mate:up:
Thubans need less voltage to get to high clocks,i run at 4.2ghz 24/7 and only needs 1.472v,to bench at 4.3ghz i need 1.490v,still playing with settings and voltages.
http://i572.photobucket.com/albums/s...0000000000.jpg
yes, this chips are a bit better than C3 Denebs for OC. The best AMD monster to time :)
Sorry no quad or six core here ....but cinebench 11.5 though :rolleyes:
http://www.rol-co.nl/hwi/amd555/cinex2.jpg
moorhen2: of course ,-)...still waiting for motherboards (Crosshair IV and Gigabyte). But it will only air.
EDIT Chart updated and moved
ReKcOlNu : nice!!! Can u add info about coolings? Thx.
Are i7s welcome in this thread. I don't want to step on any toes, or get flamed.
Imo, it's not the same. It's equivalent to something like 1.625 - 1.65V for Deneb, in order of the temperatures. Well, it might be my chip is hotter than others, who knows.
ReKcOlNu: Very nice :)
Well, it's in the AMD section, so it's supposed to be only for AMD cpu's. There's another thread for all in the main forum.
Actually there are i7 in the table, so why not...
Glad you guys like the chart.
I wanted to add OS+32-64bit/OpenGL stuff too (and even cooling would be possible) but its lot of data to hunt down and enter, so I just went for complete data and single CPU setups.
I'm not much of an overclocker, just highest stable (24/7) CPU speed with all voltages at default, CnQ/C1E enabled. Never bothered to bump up the NB-CPU MHz or anything, I actually use this PC and can't afford it to crash.:p: I'm just happy its stable as an X4. :)
MSI 770-C45 (BIOS 1.3)
CPU: X2-550(C2) @ 206x17 w/ThermalTake Big Typhoon cooler
Dram: 668MHz (1333) @ 9-9-9-24-30-1T
OpenGL score was done with a HIS 5670 512MB.
http://img410.imageshack.us/img410/8659/cb115ati103.gif
chart updated and moved
awesome chart ReKcOINu!
I.nfraR.ed, whats your secret!?! great scores man :)
1055t is such a great value :yepp:
What secret? :p:
There's no secret. I've tried also with second run, but I get almost always the same result. Maybe the memory with some of the subtimings tweaked makes the little difference. Also the high CPU-NB...
However the OS is not tweaked in any means, it's standard installation of x64 Windows7 Ultimate.
And btw the score with 955 was with cold air. With normal ambients in the room I could do only 4.2 - 4.22GHz, the heat was a problem.
ran a 7.73 last night
http://i271.photobucket.com/albums/j...tan771/773.png
Nice run Titan, what was the max cpu temp?
I hope I can join in the 6-core race soon..
pretty soon you'll hit 8s :up:
Good cooling then!
My is hitting 54C after just few minutes of stress.
I must start thinking seriously about water again :yepp:
@Manicdan
Great idea!
I can contribute Stock 1090T:
http://img168.imageshack.us/img168/5...632ghzstoc.png
good, cause we will see diferent between motherboards and setings RAMs etc etc
