yea zip ties FTW, screw paying through the nose for fancy clamps!
distilled water is used because its much harder for bacteria to grow and has fewer chemicals in it... with that said i wash my parts with tap water and dry them then fill with F1 because it looks pretty... otherwise id use tapwater and some ptnuke or something...
Well I said I have seen the light.... I thought zip ties didn't cut it, but I was wrong. I apologize for my previous comments. I also only have used the worm clamps and the Swiftech clamps, which I agree are a pain to remove. Maybe next time I will try the ziptie idea. :)
I don't think you use destilled water in your watercooling setups. Look closely at the bottle, I think it says demineralized in small letters somewhere.
