that bios blowed for me...i couldnt even post at 2-2-2-11 timings. bleh i hear its good for ocz ram. Any other bios's out there i could try?Quote:
Originally posted by clockedOut
This is the 12-18 beta bios fixes...
BETA BIOS: N24IDC18.bin
Explanation for the file name of the BIOS:
"N"Force "2" Ultra "4"00 "I"nfinity "D"FI
"C" (12 in hex, which means the twelfth month of the year) "18" (Date 18)
Disclaimer :
This is a BETA BIOS for the DFI NForce2 Ultra Infinity motherboard.
Please use it at your own risk. DFI is not responsible for any damage
as a result of using this beta BIOS.
Key Changes Since The 11-27 BIOS (11-27 BIOS is an OFFICIAL BIOS)
1. Added the 12.5X multiplier to enable more aggressive overclocking
2. Improved DRAM compatibility when dual channel DRAM is populated
in the DIMM 1/3 slots instead of the DIMM 2/3 slots
3. Enhanced DRAM overclocking ability when the memory used requires
3.0V or above to perform at high FSB with satisfactory stability
4. Updated the Silicon Image 3114 BIOS to the latest 5.0.31
5. Changed the Optimal and Aggressive CPU Interface Table above 200 MHz FSB:
- OPTIMAL CPU Interface has been modified to be more user-friendly
for high FSB overclocking
- AGGRESSIVE CPU Interface now recalls the lost bandwidth when FSB
is above 200 MHz and at a multiplier that is under 10
