That was my very first thought when I saw this thread. I use a TN panel now, but I paid $200 for mine about... Two years ago, almost?
No way I'd pay $450 for this. For $450 I could get two 25" 1920x1200 LCDs and run dual monitors.
nice stuff. Whats the technology which makes Alienware monitor to be 3d?
Helmore
Thank you, thats clear now. I wish I had one :up:
Quick question: Is there any 120hz, led backlit, 1080p monitor readily available in the market right now?
You can't be 100% certain that the 1080p 120 Hz ViewSonic will actually have less backlight bleed than your current monitor. Not until you see any tests though, but the mere fact they used LED as back lighting will not guarantee you it will have less BLB. I'm not saying BLB will be the same or worse, it probably is better, but you won't know until you see it for yourself.
Its a case by case scenario, my xl2370 has very low bleed. Its a different kind of light bleed though, the led almost makes the panel glow, compared to ccfl. My xl2370 has a huge brightness 350cd/mm2, the dell g2410 has almost zero bleed but is also a lot less bright. Pay attention to brightness, that will tell you if it has more bleed than not. I can handle a little light bleed for the extremely bright and crisp colors I get.
Nvidia 3d vision isnt worth upgrading for. If thats why you want a 120hz monitor your making a mistake. Buy a 120hz monitor for smoother frames and clean images. 3d vision sounds a hell of a lot cooler than it actually looks.:down:
Just ordered mine, will put up a mini review when it comes (5-7 days)
Yes I know LED isn't a garantue for less BLB but in my case the BLB is very disturbing cuz it's like totally blue! I don't mind the little grayish BLB I can notice in the other edges but the blue tint black has at bottom edge is totally disturbing:
http://img689.imageshack.us/img689/5290/img0271p.th.jpg
Brightness at 100% in that pic, ofc it helps a lot by reducing brightness but even at like 25 it's still very noticable in dark scenes.
http://www.dell.com/us/en/dfo/periph...ll-u2410&s=dfo
http://www.tftcentral.co.uk/reviews/hp_lp2475w.htm
Maybe those...
To topic:
I've now used to 22" 1680x1050 which is 16:10, and I definitely wouldn't want to go for 16:9... this FullHD hype is just Full marketing. If you do anything else than watch movies (which will most probably still leave black edges because most of them are not 16:9), you'd be better with 16:10 ratio. And watching video on a TN screen... its something I never want to do again after I'll get rid of my TN-sh*t (Samsung 2233BW)
Not sure if this is UK only but this code gives you 10% (£45) of the screen JH5T0BP6V8374D
