Too good !!!!
Too good !!!!
Great work :up:
Nice block Duniek...Nice mobo by the way :> Only one GPU card will be instaled ?
ram block finally for me
I will try both versions and keep that which will look better
http://img197.imageshack.us/img197/4681/ram1op.jpg
I dont like making any ETAs on my personal projects bcoz always i have better job to do but if all will be work out as i except version 0.98beta will be done @ 20th April
Wow...Both are wonderful. :yepp:
wow, nice work man!!!!
Beautiful blocks! You need a better camera to do them justice :).
BTW what sort of cnc do you do all of your work on (that is if you use a cnc at all?) is it a big one or just a desktop?
How much weights the full combo 3kg?:eek: But it looks awesome!
Hello guys the fullcover I received a while but I just plugged in, has anyone had problems sealing gaskets or problems to the threads on the plug or cracking of Plexiglas because the holes are too close??
Oh yes, we made a groupbuy and nearly all HK Plexi Tops from Duniek cracked - we´re waiting since 3-4 Weeks for the money retoure :(
http://www.hardwareluxx.de/community...694625-11.html
Does not change the pieces, but we returned the money in case of problems ...
then you must order the fullcover koolance
