I heard, that is the difference between the "two" pieces of motherboards in overcloking. Its true? The same CPU on one board example 3990MHz top and at second at 4020MHz example.
I have run my 955BE C3 on one M4A79 Deluxe board and also GA-790FXTA-UD5 the difference is to small...+-5-10mhz not more its more about the paste on the cpu.
But maybe some boards gives abit more vcore on same settings..then give you some mhz more....But i realy think this days the diffrence is not much.
It takes time, but it pays off and for me tweaking memory is the main part in the overclocking I do. I memtested 3 days straight when I got my AMD setup just to work out some basic settings.... :rolleyes:
still no luck to get my memory stable. Tryed my Corsair 1866 cl7 mem ( gtr or gts ) and same problem. no stability, only stock speed is fine.
Blue or white slots ? Blue slots are far more stable then white slots on my board...
anybody got bios screen shots for the memory?
was curious as what the ranges of settings were for volts and dividers
ah found great review of up close pics and bios settings
http://www.motherboards.org/reviews/...ds/2004_4.html
Damn , bad bios support from gigabyte (N) we want new bios! :D
Tried yesterday all nite to get over 1700mhz with the Corsair GTX2's, no go... I can go over 1800 dead easy with ganged mode, but I prefer unganged :D
Will crosscheck with the MSI GD70 this week (to rule out my CPU), MSI Nl is advised of my findings, let's hope something comes through...
We even tried on LN2 at -100°c (massman was here) last monday, errors out on memtest 5 ( 10-160 errors ) each time... 1702 was max here (recap that I'm an AMD nOOb) any higher and windows stopped loading, froze, etc... we messed with the strenghts and co, but did not find the magical setting (yet). Rams are fine ( did 2100Mhz C7 on I7 ) My air tests are almost completed will pass the board to Pj for some more cold tests...
This was on the bad batch of hypers. My GTX 2 are a heck of alot better but i need to finish up a review on them first before i beat them up.
Same board, f2 bios, weak IMC chip bad elpida batch 1866 c7.
http://chew.ln2cooling.com/brazil/32...test%20run.png
I'm overlooking something then in the bios for sure (even went command rate 2, looser timings) I'm stunned and perplexed now Brian...
I can't believe there's not an f3 bios out. seriously.
No clue i sent out emails.
no :banana::banana::banana::banana::banana:.. I finaly managet to get my D9GTR csx diablo chips run 900 mhz 7-6-5-20 1t @ 2.2v It seems, that motherboard have problems with my MSI HD4850 bench card :down: switched cards and 3d runs fine.
Arghh, still waiting for newer bios!
Any new bios for FXTA? :rolleyes:
what's the issue with your board? why do you need a bios update?
got a alpha/beta, will install it as soon as I can... no idea if I can distribute it... keep you posted
