Originally Posted by
GSKILL TECH
We do not list any AMD platforms for the DDR3-1600 CL7 spec and others such as DDR3-2000 because not all AMD systems can run these. If we state that it is compatible with AM3 systems, many people with CPUs and mobos that are unable to handle the rated spec, expect it to run at spec, then when they can't get it to, it's "bad ram".
QVL from mobo manufacturers are memory kits that they have tested, so if their tests have shown to be compatible, they list it on their QVL. Our QVL is what we have specifically tested on.
Most LGA1156 memory should have no issues with LGA 1366, although it is not guaranteed since we do not test them specifically for those platforms.
Thank you
GSKILL TECH
