next time Case two rooms to create a block of aluminum panels
Attachment 99571
Attachment 99572
Attachment 99573
Attachment 99571
Attachment 99572
Attachment 99573
Thank Aquatuning:)
Attachment 99574
Attachment 99575
Attachment 99576
Slave runs out and Topufan
Bitspower G 1 / 4 "Black Sparkle 45 Degree IG 1 / 4" Adapter
Bitspower G 1 / 4 "Black Sparkle 90 Degree IG 1 / 4" Adapter
Cooler Master High Performance 120MM R4 Series RED LED Case Fan
Tygon R3400 1/2" ID (3/4" OD) UV Resistant Tubing - Black
Attachment 99577
Attachment 99578
Attachment 99579
Attachment 99580
http://www.xtremesystems.org/forums/...8&d=1260580838
Your dachshunds will thank you to quit smoking cigarettes.
The wires look beautiful BTW. ; )
This is a test of flow
Attachment 99584
Attachment 99585
Attachment 99593
Attachment 99594
Attachment 99596
And decided the line:up:
Attachment 99588
Attachment 99590
Attachment 99591
Attachment 99592
Attachment 99589
really nice work noeru....
out of curiosity, why the one black line as opposed to all clear or all black?
--j
Thanks for sharing your work Noeru! Have an800D here and need ideas.
have some questions:
do you intend to put the mid support foot back under the case? is it sagging or it that the picture?
what made you put the rads outside of the case? not enough room inside or do you yust like it?
Nice work!!
Thank you very, very grateful:)
Yes! This black line has no special meaning
I tried it out, I will revert to the original Tygon3603;)
Thanks for the question Sorry I'm weak in English
Room dividers will be rad support.
Looking to put the rad? Put the rad outside the case?:confused:
Attachment 99614
It's alive!!!
HI Noeru! Yes confusing you here :) sory for that! Was refering to the rad fans in the top. earlyer you showed all internal. too tight?
buccaneer what rad are you talking about? Or has he sent you secret pics i can't see.
Ha ha Only now I noticed that those fans are layinh lose on top of the case! indeed confuced me. nice work!!!!!!!
Very nice set up. Are you running one loop with all? Did you end up using both pumps or just the one. Ca you take a pic of the pumps in the bottom.
Great work
Chad
OOOO how are those fans?! i was looking at those. are they actually silent? can we get more pics of em?
Pretty nice work!.
I would like to ask you, which is the trip that the coolant makes on your system? and also, have you used 1/2 ID 3/4OD compression fittings for your tygon 1/2ID 3/4OD??
About the latter question, I will use the same specifications and well I am a little bit afraid that the compression wont be tight enough.
Amazing job on spacing! I don't think you can put anything more to it.
Great wlog matey :] One question worries me - is your cute dog longer than xspc 480 or not?
hello Weevil I respect thank you dear represent:)
Sorry I'm late:)
It is a thing of the Top rad data XSPC RX480 125mmx58.5mm 25mmFan press - you can :up:
Attachment 99712
Attachment 99713
Attachment 99714
Attachment 99715
thank you ^^;
Yes, it is one loop. Consider from watching the water temperature to change the loop.
Now DDC3.25x2 XSPC Dual Acrylic Top for Laing DDC is.
Attachment 99716
SSD has taken the time to repair broken away
Yes, I want your photo shows ^ ^
Thanks for your question if the answer is, I ask you a question again
yes,this Tygon 3603or3400 is 1/2ID 3/4OD This could ensure the flow of many
11/8mm was previously
Thanks If your reference:)
I was once where I validate the air flow case
http://www.xtremesystems.org/forums/...0&d=1260026065
Conditions: Each bench tests conducted in closed cases
Core I7 920
Xeon W3540
Xeon W3520
OCCT or PrimTHtest(3hr)
Attachment 99727
Attachment 99728
Attachment 99729
Results:
Measurement place 6 points
・Aquatuning Thermosensor In- Out Thread G1/4 x2
Top rad out Watertemp
botom rad out temp
・Mcubed Thermosensor Push/Plugin Bronze 10mm x1
Reservoir
・Temperature Sensor x3
case out temp
Middle of the case
botom rad out air temp
Flowsensor is
・aquacomputer Flow sensor "high flow" G1/4
・aquacomputer aquaero
Attachment 99745
botom rad out temp
Attachment 99744
Attachment 99746
OCCT I7 920 4336.3 coreV1.375V
Top rad out Watertemp: 28.1℃
botom rad out temp: 27.7℃
Reservoir temp:27.5℃
case out temp:21.1℃
Middle of the case:25.8℃
botom rad out air temp 26.0℃
Flow 277.12L/hr
Fan is top 980rpm
botom 1000rpm or 1200rpm
Attachment 99747
Prim (3hr) xeon3540 4519.6 corev 1.376(BIOS1.45)
Top rad out Watertemp: 26.2℃
botom rad out temp: 25.8℃
Reservoir temp:25.8℃
case out temp:21.5℃
Middle of the case:24.7℃
botom rad out air temp 24.7℃
Flow 281.27L/hr
Fan is top 980rpm
I am pleased with the outcome is:yepp:
