Some more pictures...
http://farm3.static.flickr.com/2683/...104fcf5c_b.jpg
http://farm5.static.flickr.com/4064/...43302019_b.jpg
http://farm3.static.flickr.com/2794/...0f5464c9_b.jpg
http://farm3.static.flickr.com/2577/...42e34833_b.jpg
http://farm5.static.flickr.com/4048/...c8df88df_b.jpg
http://farm5.static.flickr.com/4035/...f3176bd8_b.jpg
Higher f-stop and a tripod both make a world of difference!
I have an EK 360 rad and UN rad brackets on the way along with some other little things to help complete the build. The EK is thinner, and the UN brackets take up less space behind the slot covers. This will allow me to mount the rad further toward the front, allowing room to mount the pump/res combo using a UN 120 Z bracket and iandh stealth clamps. I think this will be better for tube routing. If I need to go thinner on the rad, I'll get the swifty.
Loop order:
Res>pump>rad>top mosfet>side mosfet>cpu>ram>chipset>gpu>gpu>res
-TadZilla
