TJ(watercooling)7
TJ(watercooling)7
No wathellcooling :upset:
I have just receive the RAM from g.Skill.
http://cyril06.free.fr/sponsor/gskill.jpg
It's F3-16000CL6D-4GBPIS :
http://cyril06.free.fr/sponsor/gskillpi.jpg
http://cyril06.free.fr/sponsor/gskillpi2.jpg
w00000000w :shocked::shocked::shocked:
I love your log :clap::clap::clap:
It's so super clean and every work you do looks great at the end
I wish I could work like this on my TJ07 but i have not enough gods :)
and tools
I thought aircooling is the best for years, but since last christmas i have water in my PC
and it looks great (and works great :p)
I think it would look great in your system too :up:
keep on working like this
I will change my CPU for a Core I7 870 and I read that they're quite hot ! So I'm looking for a (may be) watercooling. I will see...
YEAH
all TJ07 owner will get a watercooling :)
allways the same
first aircooling but from time to time the watercooling comes
you can't do anything
this is TJ07 power :D
TJ07 watercooling power is in me now !!!
I would like to watercool the cpu and my two GTX 275 but let the rad, the pump and the res on the bottom of the case.
Do you think it's possible with the EK online shop ? http://www.ekwaterblocks.com/shop/
well i could make you a list of things you "have to" buy
give me a few minutes ;)
And I give you the links to a German shop (i buyed my watercooling there)
Radiator: XSPC RX480 Quad Radiator
Fans: Noisblocker NB-Multiframe or Fractal Design (because of sponsoring)
Tubing: 3 meters Tygon R3603
Pump: Laing DDC-pump 12V DDC-1T + EK Water Blocks EK-DDC X-Top Laing DDC V2
Pump Decoupling: Shoggy Sandwich
Reservoir: EK Water Blocks EK-Multioption RES 250 Rev.2
Fittings: 14x Bitspower ID 11mm + 6x Fitting 45° + 2x Bitspower Fillport (for the midlplate) + 4x Bitspower 90° + 1x Koolance Doppelnippel + 1x T-piece + 1x 2-way ball valve brass + 2x Phobya variable SLI/Crossfire VID connection (think that's all...It is allways better to buy some more pieces of the fittings)
CPU Waterblock: EK-Water-Blocks-EK-Supreme-LT
GPU Waterblock: 2x EK Water Blocks EK-FC275 GTX
Controller: Aquacomputer aquaero
Fluid: Feser One (Color???)
Please correct if something is missing :)
Don't buy at the "trademark grab" shop that Toro recommends. Why? Because it is very bad what they do imho: http://www.xtremesystems.org/forums/...d.php?t=226794
Hello Toro :)
It was just an exampel for the products :)
In the last weeks AT made a bad job...
Servus Nils :hump:
:rofl:
P.S. @ Nils "was heißt trademark grab?"
Wow Toro ! Nice rig ! Thank you. But I will take only from http://www.ekwaterblocks.com/shop/
Do you think a 360 rad will be enough ?
Does a controller is indispensable ?
Does the reservoir can be put horizontal ?
I think a 360rad will be enough
but it doesn't look as well as a 480 rad
example from my TJ07:
http://www.abload.de/img/img_1786k187.jpg
don't criticize the painting
it will get a bether painting soon :)
well a controller is indispensable, but the problem is, your fans can become very loud (if you haven't special silent fans) and the next point is the aqauero LOOKS SO :banana::banana::banana::banana:O :hump:
and I think it's no problem to put the reservoir horizontal
I have a look to ekwb
€: you can't buy all items in th ek online shop... they havent everything you need
Nice TJ toro ! I like your circuit. I would like to do something similar, with no tubes everywhere... Very clean.
The controller is only for fans control ?
Can you do the same list you did for me but from EK Shop (for what they have) and from http://www.aquatuning.fr or http://highflow.nl for the other thing ?
It will be very kind ;)
Do you have some photo of the bottom of the case ? With the pump and tube ? To see what it can looks like !
The list I gonna make tomorrow
I search for a pic of the bottom...
2x http://www.ekwaterblocks.com/shop/bl...gw-nickel.html
1x http://www.aquatuning.fr/product_inf...-775-1oe-.html
1x http://www.ekwaterblocks.com/shop/re...rvoir-250.html
1x http://www.aquatuning.fr/product_inf...2V-DDC-1T.html
1x http://www.aquatuning.fr/product_inf...tal-cover.html
1x http://www.aquatuning.fr/product_inf...-original.html
1x http://highflow.nl/radiatoren/highfl...-radiator.html
4x Fans you want
14x http://www.ekwaterblocks.com/shop/fitting-3-8-id.html
1x http://www.aquatuning.fr/product_inf...---2-Slot.html
2x http://www.aquatuning.fr/product_inf...el-coated.html
6x http://highflow.nl/aansluitingen/fit...4-adapter.html
4x http://highflow.nl/aansluitingen/fit...8-fitting.html
1x http://highflow.nl/aansluitingen/fit...ny-bp-tmb.html
1x http://www.aquatuning.fr/product_inf...1-4-Typ-2.html
1x http://highflow.nl/aansluitingen/fit...p-wtp-c42.html
3x http://www.aquatuning.fr/product_inf...ansparent.html
1x (if you want to controll your fans and your pump) http://www.aquatuning.fr/product_inf...hite-blue.html
What would you like for the fluid? With Color?
You're the best Toro ! ;)
Few questions ?
- Does the reservoir size matter ? What does it change ?
- What is this ? http://highflow.nl/aansluitingen/fit...p-wtp-c42.html
- For what to do ? To fill in ? http://www.aquatuning.fr/product_inf...1-4-Typ-2.html
- This is for the middleplate ? http://www.aquatuning.fr/product_inf...el-coated.html
1- The size doesn't matter...(i don't think that there are differents in the temperature
2- You need this for the T-piece and for the Ball valves
3- This is the Ball valves (it is for making the system empty of water, for example when you make a Hardware update you have to empty the pc)
4- exactly
Do you have Skype?
So i could help you by installing the watercooling :)
You could invent a Faceplate...like murderMod or my faceplate:
http://www.abload.de/img/img_1791tx2z.jpg
http://www.abload.de/img/img_14817hpj.jpg
I've made a custom backplate (that is not finished...)
I made my own list. Tell me what do you think about it :
CPU : http://www.ekwaterblocks.com/shop/bl...hf-nickel.html
GPU : http://www.ekwaterblocks.com/shop/bl...cb-nickel.html
Reservoir : http://www.ekwaterblocks.com/shop/re...rvoir-250.html
EK-Anti Cyclon : http://www.ekwaterblocks.com/shop/re...ti-cyclon.html
Radiator : http://www.ekwaterblocks.com/shop/ra...ad-xt-480.html
Fans : http://www.ekwaterblocks.com/shop/ra...xl1-rev-3.html
Pump : http://www.ekwaterblocks.com/shop/pu...s-mcp-355.html
Pump top : http://www.ekwaterblocks.com/shop/pu...etal-g1-4.html
Tube : http://www.ekwaterblocks.com/shop/ac...-uv-white.html
or : http://www.ekwaterblocks.com/shop/ac...-uv-black.html
And fuel : http://www.ekwaterblocks.com/shop/ac...ue-1000ml.html
And for fittings I will choose bitspower.
I don't like the tubing
Masterkleer isn't as well as Tygon
and i think the clear tube looks better than the white or the black
And the fluid is not so good
This is a good Fluid
Link
and the fittings take all i choose for you
Face plate looks good there toro
Does the line in the middle lights up as well?
