Looking good there, just keep an eye on the temps, if they go any higher get a better heatsink, also you don't want to be running prime to long as its only wasting time and degrading the CPU as it is fully loaded all the time.
There are two options for you as you say, for gaming there is not that much difference between the REII and MF3, the REII will be the better bet but is more expensive and then you have the CPU which again is more expensive, an i5 750 would be good enough with a slight overclock on it for gamming but I don't think you would need the MF3 for this, see my Review of the P7P55D Deluxe with all tests shown with core i5 750 running at 4000MHz
http://www.xtremesystems.org/forums/...d.php?t=233975
